Marc's S2- Autozam AZ-3 B5ZE -BOOOOOSSST videooooooo
marcdh
Re: Marc's Sooty 2.0 - Autozam AZ-3 B5ZE -New windscreen&5st
Post by marcdh »
In the middle of exams now. Bit of waxing for stress relief.
View Worklog
marcdh
Post by marcdh »
Soon... Very soon my pretties!
Rx8 425cc denso injectors
View Worklog
RobMinhas
Post by RobMinhas »
Any particular reason you went with rx8 injectors vs. the 450cc RX7 ones most people use?
marcdh
Post by marcdh »
Well availability, price here, high impedance, age and spray pattern. Didn't overly research it but an easy direct swap with no mods for diypnp :)
View Worklog
RobMinhas
Post by RobMinhas »
I thought the RX7 ones were the same impedance?
And that's pretty cool, they look slimmer, still fit up fine?
kulluminati777
Post by kulluminati777 »
The picture with the rainbow is cool!!!
marcdh
Post by marcdh »
Polyurethane filled mounts! The cheap way to firm mounts:
Painted and filled rear:
The front is installed, cba installing rear this morning! I've been working a fair bit so alas turbo progress is slow.
Also removed the AC pump, rad, fan, hoses etc. much cleaner engine bay!
Finally got the right adaptor for oil feed off the head:
1/8 BSPT (tapered not straight!) to AN4 (7/16 JIC UNF)
View Worklog
Post by Josh »
Not cheep, that is the right way to fill mounts! Looks great.
marcdh
Post by marcdh »
Cleaned up:
Rare sunny shot:
View Worklog
marcdh
Post by marcdh »
So I appear to have a B3S7 flywheel (same as 1.3 festiva?)
Today's work in a few photos!
My view for a fair bit of today:
Hours of work for this lol:
Not helped by A LOT of this:
So that's the horrible oil return job done. Alignment to the turbo drain is brilliant. Next step intercooler piping!
Oh yea and on Friday I also sorted out this disgusting sight:
And made this fit the B5 setup:
View Worklog
marcdh
Re: Marc's Sooty 2.0 - Autozam AZ-3 B5ZE BOOOOOOOOST WOOOO
Post by marcdh »
Not bad for a 1.5 :lol: for whatever reason its only hitting 6psi but that's feeling pretty fun right now :-D
More on this tomorrow!
https://www.youtube.com/watch?v=YWjTBZX ... ata_player
View Worklog
youdirtyfox
Re: Marc's Sooty 2.0 - Autozam AZ-3 B5ZE -BOOOOOSSST
Post by youdirtyfox »
:D Nice result indeed, look forward to seeing more on this!
marcdh
Post by marcdh »
Cheers Sam! There are some strange smells going on, hopefully not my clutch :lol: The manifold has turned a pretty golden colour now.
View Worklog
youdirtyfox
Lets fookin hope not man! Mmmm do love hot stainless colours :D
Post by Josh »
Nice work!! That is about spot on for HP. Your mani should start turning a shade of purple if you go on some long drives. At night if you pop the hood after a drive you should be able to see it glowing red. Look forward to seeing more!
