At last, MX-6 ECU + KL02 vs. Probinator + JE50 dyno results.
Vanished
Re: At last, MX-6 ECU + KL02 vs. Probinator + JE50 dyno results.
Post by Vanished »
Keep us posted guys...I may have to try out a new combo here for shits and giggles.
Good thread.
1992 Blaze MX-3 GS *R.I.P.*
1993 Blue 93 SE-ZE
http://www.cardomain.com/ride/2770987/2
Mad Cow
Post by Mad Cow »
I think I might just get a KL02 from a junkyard and test it with my probinator. If it's not good then I'll just return it.
KLZE-ed '94 RS/'92 GS hybrid -- It's complicated :lol: -- Now somebody's winter beater
1999 Audi A4 2.8Q -- New ride
Post by wytbishop »
Mad Cow wrote:I think I might just get a KL02 from a junkyard and test it with my probinator. If it's not good then I'll just return it.
Tried it...sucked...took it back.
neli_nael
Post by neli_nael »
joke or not it was funny. :lol:
94 mx3 rs
92 mx3 gs curved neck klze SOLD
Post by wytbishop »
No joke. I did exactly what Mad Cow said he was going to do. It was not a successful trial.
Mad Cow
Post by Mad Cow »
Really? That's weird. :? But I'm stubborn so I'll try it anyway. :lol:
Dragyn Vyrus
Post by Dragyn Vyrus »
i have no idea why mine seemed to like it more. i did however swap them when i have the k8 TB on, so maybe i'll go out and try the JE50 back on the ze and see what it does. i don't know how we are getting varying results...
mine is a straight neck ZE, but that shouldn't make much of a difference because so is wytbishop
edit: i just tryed the JE50 out. i noticed that is was pretty close to the KL02 for the bottom end, but the KL02 preforms better than the JE50 in the top end. i went to go and swap the JE50 out for the KL02 in a parking lot and then it started to die and sputter, did not want to work and became a big crap pile.
on a side note, odd one too. With the KL02 i get a regular amount of valve noise(or something along those lines anyway) especially at idle. but when i switched it over to the JE50, all of that vanished. :confused2:
93 MX-3 ZE-GS - Sold
95 MX-3 RS - Bone stock winter car.
92 JDM turbo MR2 - SSQV, Cusco strut tower bar, ATS intercooler kit, Berk Exhuast, HKS EVC-S
Mad Cow wrote:Really? That's weird. :? But I'm stubborn so I'll try it anyway. :lol:
grab the ecu that goes with it while you are at it trying things :roll:
onlytrueromeo
Post by onlytrueromeo »
I also tried the kl02 today with no success.
The problem is the car idles too low so it runs bad. If you rev it, it sounds perfect, and I didn't see any black smoke out the back. I tried adjusting the idle/timing to no avail, so I can only conclude that it won't work w/ a probinator for an MX3.
I am still debating whether or not to get a coder and play with the values, or if I should buy a different ecu...if I go this option though, I will have to get another probinator chip to remove the EGR codes and rev limit and speed limiter, etc.
RX8SE3P
Post by RX8SE3P »
You guys simply can't go an label the KL02 as crap if you are not using a MX6 ecu or an ECU that is chipped/meant to go with it.
It will idle low, stall etc. With the correct ECU it will have no problem.
The probinator chip is probably set up for the JE50 - if you guys told Probinator you had an MX-3 he would most likely set it up for the JE50 IMO.
1995 Eunos 30x KLZE
Post by wytbishop »
That was my only point...to see if it worked with the JE50 as people were wondering. I will try it with an MX-6/Probe GT ECU as well.
onlytrueromeo
Yeah rx8, we know that - lol, we're not stupid.
Whisper
Post by Whisper »
One cannot be told that KL02 VAF doesn't work with JE50 Probinator - it is something you have to see for yourself. :wink:
Well, this is the reason, if you read the Probinator's (cardomain) site, it lists this:
Eliminate the need of a JE-50 VAF
Yes, typically, you need a KL02 VAF with a KLDE ECU (apparently the KL02 runs good on a K8 ECU too), but after reading that, you'd think that you could use a JE50 VAF or a KL02 VAF without any difference.
Mad Cow
Post by Mad Cow »
Nd4SpdSe wrote:Well, this is the reason, if you read the Probinator's (cardomain) site, it lists this:
But that seems impossible because they give different readings from what I know, so that means it'll need 2 fuel tables and be able to differentiate between JE50 and KL02.
EDIT: Just a random thought, what if the K8 ECU is different from the KL01 hardware-wise? I'm pretty sure the probinator wasn't tested in a K8 ECU, so that might be the problem. Does anyone have a probinator chipped KL ECU?
