Turbochaging K series motors - walkthrough
Re: Turbochaging K series motors - walkthrough
Hold on a sec ...
if i order this :
http://cgi.ebay.ca/Ford-Probe-Mazda-MX- ... ccessories" onclick="window.open(this.href);return false;
and this :
http://cgi.ebay.ca/T3-T4-TURBO-KIT-FORD ... 240%3A1318" onclick="window.open(this.href);return false;
can i drive my car to work after assembled ?
if i order this :
and this :
K8 :: 136.8 bhp---160 nm---108.0 whp---118lbs/torque
ET: 15.567 @ 136 kmh (84 mph)
"Racing a Honda is like being in the special Olympics, you may win, but in the end your still retarded."
- johnmx3ze
dont forget the most important thing the megasquirt...OutlaW wrote:Hold on a sec ...
if i order this :
and this :
what will happen if i dont get a megasquirt or similar ? the car wont run ?
- marcdh
Would have thought you'd need at least a RRFPR and some DE/ZE injectors to avoid being mega lean. Wideband would help with that.
View Worklog
View Worklog
- johnmx3ze
yeah sure it would run but like s---... i know a megasquirt is alot of cash but its the best thing you can buy for your turbo setup... i ran mine with my FMU for about 20km and i just cant trust it... now i have my megasquirt and im not worried at all...OutlaW wrote:what will happen if i dont get a megasquirt or similar ? the car wont run ?
if ever i do an other turbo setup the first thing i will buy is the megasquirt, i'd buy it before anything else...
- se7en
2nd, Msns is the way to go.
projectzemx3
what about the subframe? i thought you had to modify the subframe to fit those turbo pipes?
NEED PARTS INSTALLED? PM ME!
- marcdh
Yea you gotta cut extend and weld the engine mount xmember for the downpipe to pass through. Not a huge job though!projectzemx3 wrote:what about the subframe? i thought you had to modify the subframe to fit those turbo pipes?
View Worklog
View Worklog
se7en, i just saw a report about the Genebra car show , and they were showing a glipse of the new Alfa Romeo MiTo GTA.
It's going to have a 1.8 turbo with reliable 230bhp .
Can we have similar bhp on a reliable source, or is the AlfaRomeo engine just stronger ?
It depends on alot of things. 210bhp on a 1.8BP would be no problem, on a K8, it may or may not be doable, but it'll mostly depend on the motor. Mazda probably never intended to boost the K8, and that's the problem. It really all comes down to the design of the motor. If they built it to handle boost, 230hp should be no problem. I think most who boost their K8 run around 200bhpOutlaW wrote:se7en, i just saw a report about the Genebra car show , and they were showing a glipse of the new Alfa Romeo MiTo GTA.
- se7en
200bhp??
it's not the engine that is the weak link at all...mine was the g-series trans...third gear is sooo weak..
I am still running approx 250-275Whp, with no engine problems at all...but the trans on the other hand....
1st 2nd, and fourth....not a fun transition
should i had this to my shopping cart ?
http://cgi.ebay.ca/MEGASQUIRT-II-2-PCB3 ... 240%3A1318" onclick="window.open(this.href);return false;
and will this bolt on to my K8 ?
http://cgi.ebay.ca/ACT-6-PUCK-CLUTCH-DI ... 240%3A1318" onclick="window.open(this.href);return false;
just checking..are these the right pipes? and will everything be much easier if im doing this with the engine out? because im converting to klze and i might as well bolt the turbo on while engine is out right?
sorry..the pipes:
http://cgi.ebay.ca/Ford-Probe-Mazda-Mx- ... .m20.l1116" onclick="window.open(this.href);return false;
- johnmx3ze
melb30x wrote:sorry..the pipes:
yep thoses re the right ones.. just install the headers while its out...
