Page 4 of 4
Posted: October 4th, 2007, 9:32 pm
by fieromx3
lol yup i was pumped when i found we could get urethane mounts :D well i just got them in and drove it 10mins ago and they are NICE!! u can definitly tell there solid especially when ur turning it over to start! has a fair amount of vibration at idle but when moving it isnt noticeable but there niiiiace :)
my old mounts are ''brand new'' only like 24k KMS on them and are for sale for 45+shipping pm me if interested
Posted: October 5th, 2007, 8:26 am
by Mooneggs
Slammed6 wrote:I knew people would order those if they were made...Im glad i got them to fab those up before i ended up leaving the car scene. LOL.
yeah thanks dude! UPS has been trying to deliver my rear mount all week LOL... I think I will get it today...
Posted: October 24th, 2007, 3:17 pm
by 1992blazeredgs
Anybody else have some input on the awr mounts? I need new mounts badly but i dont know if i want to spend the money on these.
Nate
Posted: October 24th, 2007, 4:52 pm
by Mooneggs
do it! buy the AWR ones! but get a probe front and mx-3 rear
I LOVE MINE!!!
Posted: December 18th, 2007, 2:39 pm
by 1992blazeredgs
I got my awr mounts installed and they are awesome. Well worth the money, and my throttle response is rediculous now. The car feels so much more aggresive.
Nate
Posted: December 18th, 2007, 3:35 pm
by Mooneggs
1992blazeredgs wrote:I got my awr mounts installed and they are awesome. Well worth the money, and my throttle response is rediculous now. The car feels so much more aggresive.
Nate
what durometer did you get? also did you get both mx-3 or did you get the probe for the front?
Posted: December 18th, 2007, 4:00 pm
by 1992blazeredgs
I got the 88 durometer, and both were mx3 mounts. I didnt feel like drilling the crossmember holes bigger. Plus i figured solid mounts were strong enough, that i didnt need the added strength of getting the probe front mount.
Nate
Re: AWR Solid Motor Mounts
Posted: April 29th, 2009, 9:05 am
by RX8SE3P
Sorry to bump and older thread but my MX3 shudders a fair bit on acceleration. Like if I put my foot down it goes braam braaam braaam real quick like it's doing on/off acceleration. But if I slowly put my foot down it doesn't do it, just goes braaaaaaaaaaam. That make any sense at all lol?
The gear stick looks like it shudders in exact time with the engine shudder. Guessing I should have filled or gotten solid mounts as I used my old crappy mounts on my ZE lol. Shifting can be a little bit crap too, so I am relatively sure the mounts are not holding the ZE very well.
Thinking about AWR MX-3 front and rear. Is 70 durometer too soft? I don't want a super strong mount that risks breaking my engine or trans but I don't like the way it is now. Or is 88 durometer normal?
90% of the time I just drive like a granny but would like a more tight ride when I change gears and accelerate in normal conditions.
Posted: May 31st, 2009, 7:31 pm
by mazda___mx3
how do these compare with filling your own mounts with urethane?
Posted: May 31st, 2009, 7:46 pm
by onlytrueromeo
I would get 88. It's not going to break your tranny, and I really don't mind the slight vibrations. I think you want to get the probe front one, its a little beefier than the mx3 one. It's either the front or the rear, a search will tell you.
This is better than filling your mounts, but slightly more expensive. AWR only does the front and rear also, so you'd still need to fill in your sides.
Posted: June 1st, 2009, 5:12 am
by marcdh
Probe front! Much bigger nuts/bolts 19mm (socket) VS the mx3 ones which I'm guessing like the rear one has 14mm nuts IIRC. I'm really happy with 88s, it has caused one panel to rattle by the windscreen but I'll get round to that. The benefits far outweigh that rattle, really tamed my clutch. I couldn't believe the difference, I found it much better that the 70shoreA window weld in my old mounts. Though I'm sure liquid filled/2part poly would have done a closer job.
Posted: June 2nd, 2009, 3:14 am
by RX8SE3P
Well I guess getting a probe one makes sense, since it's meant for a 2.5L engine and the MX-3 mounts are probably for 1.8L engines. If all I have to do is drill the cross member holes a tiny bit, that's piss easy.
I'm waiting for a reply from AWR if they can ship them here to Australia.
Posted: June 2nd, 2009, 10:37 am
by Mooneggs
RX8SE3P wrote:Well I guess getting a probe one makes sense, since it's meant for a 2.5L engine and the MX-3 mounts are probably for 1.8L engines. If all I have to do is drill the cross member holes a tiny bit, that's piss easy.
well that logic is not exactly correct...you could drop a 1.8 in the probe and would still not be able to use an mx-3 rear mount
mx-3 or 2.5 probe front will work (I recommend probe front) just make sure you get an mx-3 rear, the probe rear WILL NOT FIT!
Posted: June 2nd, 2009, 10:50 am
by marcdh
I think he was referring to the power output (bigger engine - stronger mounts) as opposed to the shape/fitment. Though yea be sure to order:
Probe front
Mx3 Rear
