Shades - 1996 MX-3 RS
Shades
Re: Shades - 1996 MX-3 RS
Post by Shades »
Just some things I've been working on while waiting for my manny to come back...
She ain't quite done since I don't have the manny to mount the turbo in... the J bends need a piece of straight inbetween the bend.
I also had to take out the tow hooks in the front, anyone else had to do that for their piping?
"Do it ONCE, do it RIGHT!"
Shades
Post by Shades »
Who's hiding under there?
Got her back from the welder... $200 later...
More Pictures...
On a depressing note even after I bolted it to a 1/2" thick steel plate, all three flanges are warped... I'm having trouble with my intercooler piping... where I planned for my wastegate to dump, I have intercooler piping to dodge... and I started getting tired and wreckless and scratched the **** outta my wastegate.
On a less depressing note...
She sticks out 2" from the body... wow!
More Pictures...
93SOHC
Post by 93SOHC »
that is the beefiest mani i've seen in a while, hope you get your fitment issues resolved. Oh and those rims are NICE! :2thumbsup:
10secSim
Post by 10secSim »
Don't get discouraged man it's only normal your gona have to get the flanges milled down....Keep it up man i want to see some crazy vids on youtube soon
B6 1.6L DOHC, CAI, custom intake mani. with internal velocity stacks, 65mm thottle body, probe 4-2-1 header, custom 2.5" high flow exhaust, Centerforce dual friction, MS2, MSD 6A, Tokico struts, EIBACH springs.
http://www.cardomain.com/ride/2443642" onclick="window.open(this.href);return false;
hotsiit
Post by hotsiit »
:love: ...awesome wheels. nice progress.
1993 Mazda MX-3 RS-Turbo
1993 Mazda RX-7 touring
1983 Mazda RX-7 GSL
1987 Jeep Comanche
Shades
Post by Shades »
Thanks guys... yeah, I'm just stressing over the flanges. It's just that I might have to take time off work to go machine them, or pay someone to do it.
RS_OBD'oh_2
Post by RS_OBD'oh_2 »
It is common practice to surface all flanges after welding. Looks like it's going to be really tight routing that down pipe. Very nice tho. You should clean up the welds and coat that biotch.
Shades
Post by Shades »
M-Tuned Dual Feed Fuel Rail and Ceramic Coated Turbo Manifold...
This is how I hooked up the FPR... used a street 90 degree 1/4" elbow...
Ceramic Coated and Radiator spacing is tight...
These are my turbo fittings from Earl's... Restrictor, Oil, Water...
MORE PICTURES...
solo_ryder
Post by solo_ryder »
CRAZY.
Are you going to use a half rad? Is that rad gonna work with that honking turbo right up against it
Shades
Post by Shades »
It should work as is... I like the stock rad as it is very efficient at removing heat from the system. I just have to notch that top tab on the rad and she's set...
Ryan
Post by Ryan »
I definately admire your build.
Shades
Post by Shades »
Mmmhmmm...
Who's hiding?!
Oh and some new fan cause the other one ain't gonna fit with no room... might have to make it a pusher rather than a puller.
More Pictures...
Shades
Post by Shades »
A few clamps and some heat wrap are missing but you get the idea...
More Pictures...
Shades
Post by Shades »
Oh wow...
MOVIE TIME!
Hmmm... this is what you get when you have a plumber help you... home made exhaust stack with O2 sensor port!
Ryan
Post by Ryan »
I read 80% of your worklog over on CP. took me an hour.
Your build is a perfect example of what I want to do when I'm out of school, with decent income (say, 7 years?)
Absolute sex. Thats better than anything you can buy new. Its an entire aftermarket motor. You still have the stock crank, thats about it. BP cranks are awesome, so who wants an aftermarket one anyway?
How far are you going with this setup? I saw your suspension/subframe job. Going with any serious chassis work? Power isn't you're issue, its going to be keeping your wheels going the same speed as the pavement below it, and avoiding the understeer caused by wheels spinning in corners. Beefy swaybars, good bushings, and maybe consider chassis stiffening.
I love it.
