race bushings don't wiggle at all....my Z has that setup...
Shift Gate!!!
- se7en
Re: Shift Gate!!!
those wiggles you speak of are worn out shifter bushings
- onlytrueromeo
Re: Shift Gate!!!
Shifter doesnt wiggle if you get new bushings
My Shifter is tight as ****
Re: Shift Gate!!!
My shifter is so bad that it's actually a struggle to get into reverse.
But I have new bushings waiting to be put in so it's all good. If someone made a gate with longer fingers shaped for a short shifter I would be all over it.
KLZE-ed '94 RS/'92 GS hybrid -- It's complicated
-- Now somebody's winter beater
1999 Audi A4 2.8Q -- New ride
Re: Shift Gate!!!
I don't have long fingers. Mine are short and fat and an oversized palm. Meh.
What? This is important!
Re: Shift Gate!!!
Id much rather the shift gate look like this.
I quickly did this up at work today in solidworks. mind the imperfections.
could be easily machined
OSKY
95 MX-3 GS ZE Turbo: MSnS-extra, AEM WB, Blitz boost controller, MSD 6A w/ Blaster2 Coil, ZE disty, Redtops @ 550, Walbro 255, Garrett T3/T04E 60 Trim w/ .63 A/R, 38mm Deltagate Mark II @4psi, FMIC, Apexi BOV, CM Dual friction, 4-6.25 Kickers, 2ch Alpine V12. That's Alll.
http://www.pakfeifertuning.com
- fowljesse
Re: Shift Gate!!!
I got the Ebay plate today from Rekognize, and will start making a design soon. I already see room for improvement.
I bought a router at a thrift store that wasn't working well, and took it apart. It works fine, now
I'll post up a prototype soon!
- se7en
Re: Shift Gate!!!
I'd rather have one that worked for the 1992 center console, unlike the one that is available on ebay, which only works for the 1994 dash and newer...
I have the 1994 and newer one, and it doesn't fit....(holes in the wrong spot, and the shape is wrong...
Re: Shift Gate!!!
Do Want.
I just remembered I thought about doing this a long time ago, and then got side tracked. That happens a lot.
I'm definately keeping an eye on this thread.
- fowljesse
Re: Shift Gate!!!
I made a gate for my '93, and I love it. However, it can't be made like the graphic above, because our shifters don't have a path like that. It stays within a small box (about 3.5 inches). I like it. It's unique.
Here's the thread:
http://www.mx-3.com/phpBB3/viewtopic.ph ... shift+gate" onclick="window.open(this.href);return false;
Here's the thread:
