Smokey McSmokeyson!
AaronTietje - 1993 MX3 Phase 2
Re: Countdown to H2o.. AaronTietje - 1993 MX3 GS
"Hmm... Hmm.... Hmm... Hmm... "
Smokey McSmokeyson!
Smokey McSmokeyson!
- kulluminati777
ITS.....SO....BEAUTIFUL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- DeadMaker
More pic pleaseeeeeeeee...
Black Mazda Mx3 Rs 1997 B6DE
I think it's incredibly selfish of you to not post a bunch of pictures of your big brake set up. You ahve been very secretive about it all along and I don't like it....not one bit.
- AaronTietje
Lol I'm quite sure I've posted about it but here it is again:wytbishop wrote:I think it's incredibly selfish of you to not post a bunch of pictures of your big brake set up. You ahve been very secretive about it all along and I don't like it....not one bit.
1st gen Probe Hubs.
These must be modified to fit the mx-3 struts......
Or if you are running Ksports/D-2's you can order the probe hub mount lower portion of the strut assembly and it will all bolt up
I have custom brackets made for the hub-caliper. IF ANYONE IS LOOKING TO COPY MY SETUP I HAVE TWO MORE SETS OF THIS BRACKET
I then used an aluminum hat and a tenzoR 12 in brake rotor.
My setup also required custom heliocentric rings for the rotors so that they did not slop around.
My rotors are US BRAKE however wilwoods with the 5.25 in spacing will work as well.
Finally when plumbing the brake lines note that most stainless brake lines are standard. I had to convert my caliper side hard line to a standard fitting on order to bolt it up.
- AaronTietje
NO MORE KL POWER>>>>>>>BP-T all the way........Pics and details tomorrow.
RobMinhas
Thumbs up for BPT!
Sleeper6
I know now this car will never see the light of day outside of wishful glances from your garage now
- MrMazda92
What what what!?
- AaronTietje
Not cool Glenn. She will rise again..............you will see.Sleeper6 wrote:I know now this car will never see the light of day outside of wishful glances from your garage now
Anywho, pics later today.
- AaronTietje
Here it is. She's tuned in at about 13-14lbs boost.
RobMinhas
Awesome! Is that Will Thomas's car?
- AaronTietje
RobMinhas wrote:Awesome! Is that Will Thomas's car?
It is er was.
- Josh
hmmm... well you should have kept the trans with the LSD you could have swapped it into the BP trans. I am kind of surprised, but pleasantly surprised with your decision
if you could have found a FEDOHC motor it would have bolted to the GS trans and you could have used the same turbo and maps
the BPT is lighter anyways. a nice little spit shine and you are going to have a mean machine.
Do you have any kind of HP numbers on it? Is it a real BPT motor or is it a N/A BP with BPT goodies? N/A BP with the goodies will make a lot more power at 14psi. difference of about 190-200 WHP to 220+ WHP. Sorry I have questions and I am just anxious for your car to be on the road
- AaronTietje
It's a NA with goodies. Guestamation is about 240 hp. If I could have gotten my lsd to mate up to this setup I'm going to cry a river?Josh wrote:hmmm... well you should have kept the trans with the LSD you could have swapped it into the BP trans. I am kind of surprised, but pleasantly surprised with your decisionif you could have found a FEDOHC motor it would have bolted to the GS trans and you could have used the same turbo and maps
