Mi|<e - 94 GS BPT dyno tuned
- [LVPA]93GsSe
Re: Mi|<e - 94 GS BPT dyno tuned
Looks good, Can't wait to hear how you like it.
Knowing you've spent too much on your car,
yet, you still want to keep modding. -priceless
boosted_bullet
93 Honda Accord LX - Wrecked
95 Honda Del Sol Si - Stolen
92 Honda Accord EX - Parted out
2000 Toyota Celica GTS - Cracked block and broken differential teeth
93 SE - ATX to MTX, work as always in progress
01 Toyota Celica GTS - DD
Worklog to be up soon, still... ...
boosted_bullet
Re: Mi|<e - 94 RS BPT
Mi|<E wrote:Here is how to wire a 94 DOHC to protege harness.
Hey Mike, any chance you've got a high res version of this? Some of the pins are difficult to read, once zoomed in they get much too blurry.
Low compression!
These are not the problem.
What the shart is this valves, Y U FAIL ME?
Just an excuse to rebuild and make things more better gooder.
Stay tuned for more better goodering.
1994 MX-3 RS
Worklog: viewtopic.php?f=46&t=62251
B6 goodies for sale:
viewtopic.php?f=2&t=66333
2nd BP engine: http://www.clubprotege.com/forum/showthread.php?t=46695
I re ringed all the pistons with wiseco rings on the supertechs...
but I didn't take any pictures of that!
Look at the head stuff instead
Ran out of seat grinding stones, had to order more for a 45 and 30 degree cut
Valve guides are all new also
1994 MX-3 RS
This is some of the other crap I have been up to
I did test the changes on the dyno
Calg_93GS does a pretty nice polish job
1994 MX-3 RS
i very suggest to sand your quarter whose been paint be a can with 2000 sand paper to smooth all the surface then buff it it will be like a mirror after that that the secret
i think you didnt lube these cylinder before entering these piston right?
also i wanna know which toyota model did you pick for these coil pack i wanna do the same thing
and what its supposed to do?
