Page 3 of 3
Re: D^mn Honda
Posted: January 21st, 2010, 9:40 am
by Ryan
....So, you're saying we need tandem rear drive axles?
Re: D^mn Honda
Posted: January 21st, 2010, 6:33 pm
by Inodoro Pereyra
Nd4SpdSe wrote:Inodoro Pereyra wrote:Which is exactly the same as with a RWD car. Torque is always good up to a point. Regardless of the car being FWD, RWD or AWD, or having street tires or slicks, there's always a point in which you will start spinning the tires. Your point is moot.
Not at all. It's a combination of torque and traction.
Which is exactly why I said "torque is always good up to a point".
Regardless of the layout of the car, torque is NEVER useless. You just need to use different methods to transmit it to the ground, and it has different limitations.
True, applying torque on a FWD car can be more complicated than on a RWD, but that doesn't mean it's useless.
We could go on forever about the differences for each system (and yes, I'm well aware of them. Those you cited, and those you didn't), but bottom line, the fact that there are plenty of examples of all 3 systems running very high torque engines, renders the point, as I said before, absolutely moot.
Re: D^mn Honda
Posted: January 21st, 2010, 9:35 pm
by 94drumx3
Flyer wrote:If the entire point is to play the "anything you can do I can do better" game, rise up to the challenge and make some of your own...for exmaple, let's see him drive past a speed trap going five over...or leaving the car in a bad part of town for ten minutes...
lmao, you're alright Flyer...you're alright
Re: D^mn Honda
Posted: January 22nd, 2010, 11:42 pm
by xtreme velocity
ottom line hondas suck mazda rules. Let him tear up his running "11s" here before too long running his car like that he will be needing new parts. From what i have seen in mazda. They are made more for corners than straight line. Higher rpms for periods of time and suspension setup up. When he wants to race just say lets try all driver skill with straight lines and corners. He is toast then. But for the straight line get you a LS1 and he wont touch you. That motor is more or less built for straights. Keep us posted and build on your car. We want to see a cornering machine.
