Page 3 of 3
Posted: December 23rd, 2006, 11:02 pm
by mr1in6billion
jbaysinger wrote:I figure the big problem is going to be getting two independent video sources. It'd be great if the S-VID output from the Mini ITX boards was independant, but I have a feeling that it's a redundant display of whatever is on the VGA output. I was hoping there might be a MB out there that had a dual monitor setup built in, but I think I'm wishing too high.
By default the screens show the same thing (Everything I say is referencing the M10K), but I think there is an option to make the other screen an extended desktop. My computer/tv are in different rooms right now, but I'll look into later tonight.
I'm hoping I don't run into problems using a PCI board, as I'll also need PCI for WiFi I'm assuming, tho I could go the PCMCIA route for that I suppose.
The wifi is pretty flexable as there are pci, usb, and external ethernet boxes and should be chosen last. My board came with a pci riser to take 2 cards, which should be enough to support more than you need.
Pretty much anything can be run through usb or 1394 nowdays, so anything added on shouldn't be a problem. Just make sure you have enough power.
Posted: December 23rd, 2006, 11:15 pm
by Nd4SpdSe
most mini-itx systems will have a mini-pci slot, which is basically for wifi cards, so there sholdn't be a problem there.
Posted: May 20th, 2007, 12:32 pm
by jschrauwen
Barry or Mike
If you have the time to peek at this thread;
http://www.mp3car.com/vbulletin/wireles ... tenna.html
It sure would be appreciated. Perhaps you can point me in the right direction. Thanks,
John
Posted: May 21st, 2007, 9:50 am
by Custommx3
I looked through it and it seemed your questions are answered, what exactly are you looking for :)
