MX-3.com and MX3 owners on the map
- freyguy_412
- vozaday2000
Put Meadow Lake, Saskatchewan, Canada on the map.
- papa roached
im added
- GregoryChristian
Gro Harlem
added myself.
i made one of these for the protege & festiva guys yesterday lol...already got like 40 ppl on the protege one.
its pretty kew, should help w/planning meets.
ALso worth noting, ppl from other countries type ur city in SLOWLY then wait for the dropdown menu to display. If it shows a bunch of erroneous cities, type a lil bit more of your city & see what it shows.
The format for other countries HAS to be like this:
Canada:
Toronto, Ontario (Canada)
Elsewhere:
Cityname (Countryname)
Canada:
Elsewhere:
DONATE TO MX-3.COM
DONATE TO MX-3.COM
- PATDIESEL
I'm in and so close to AtlMX-3 that you cannot click on my name unless you zoom in quite a bit.
Just above Atlanta Georgia, lol
We really do live about 5 minutes from eachother.
- neutral
Yup, that baseball diamond, running track and adjacent buildings are the local high school and the nearby lake and pond are on an adjoining 100 acre park. Not quite in view of my house but I'm close enough (<1km) to walk over and play tennis etc. Can almost see my white MX-3 in the driveway but the tree cover blocks a clear view of it.jschrauwen wrote:...I notice your also in the woods too Jim. Looks like you've got a possible view of the nearby baseball diamond though.[/color]
-Jim- jaydog5678
