compression test will be done tomorrow..I didn't have a compression tester but I just got one but it's getting late and dark outside..I'll do that tomorrow
as far as the timing is concerned..both cam gear and crank pulley are like they are suppose to so that's ok
maybe you didnt burnt a couple of valves?
i don't get it
and I was wondering..what would be the reaction of the engine if the crank sensor would give up..I notced while taking off my belts that the wire to the CPS was damage (the belt almost cut it in half)
Parts needing installed: turbo kit from BB (if i ever get it), 9.0:1 CR Diamond pistons, 4340 forged H beam rods, C/J-Spec spoiler, Nissan red tops in KL rails http://www.cardomain.com/id/blazejeremy
SO I took everything out...2 cracked retainers...one was all busted and the other had a cracked in it but while taking the hla out it cracked...they are number 4 and 6 cylinder intake retainers.
SO I know intake hla's are different on the ze but does somebody know if retainers are the same as the DE too? i would guess not but I'll ask anyways
nice to know. but I'm already buying 95 millenia retainers and swapping 98+ probe solid hla..they are suppose to be way stronger than the DE and the DE are stonger then the ZE
Originally posted by babyblueMX3: 98+ probe solid hla..they are suppose to be way stronger than the DE and the DE are stonger then the ZE
98+ Probe retainers don't exist ...... at least not on this plane of reality. I hear if you fly your wormhole past a white dwarf star, you can get into an alternate reality, though. Maybe you can find a 98+ Probe there.
Originally posted by babyblueMX3: ... solid hla..they are suppose to be way stronger than the DE and the DE are stonger then the ZE
Solid AND hydraulic ???
sorry about that..it's the 98 626..I tought it was in all DE's but after some more research it's the 626 DE
