Mi|<e - 94 GS BPT dyno tuned
IMACHU2
Re: Mi|<e - 94 RS BPT dyno tuned
You must have the most understanding wife/girl friend in the world if you really rebuilt your engine in the "kitchen"
Seriously though, nice work.
Dominic Toretto's whip is a MaZda and his cell phone number starts in "(323)"
My work log http://mx-3.com/phpBB3/viewtopic.php?f=46&t=72471
TotallyNotDave
This is a amazing build Mike.
It also looks like you had some awesome body work done. Like a 3 stage cut polish or something.
That valve cover looks amazing, whoever cleaned that is surely a god.
Keep up the good work!
So the turbo has been rebuilt, bit expensive but they did a really nice job. New
turbine wheel which is a little bigger than the previous one:
Its all balanced and has no shaft play at all. Engine is assembled but now I have
to swap the tranny as the electric speedo gear ring from the mx-3 GS tranny has
fallen in and caused the gears to bind. Oh well new bearing / synchro tranny goes in.
1994 MX-3 RS
Worklog: viewtopic.php?f=46&t=62251
B6 goodies for sale:
viewtopic.php?f=2&t=66333
2nd BP engine: http://www.clubprotege.com/forum/showthread.php?t=46695
- Tavman_1213
Where did you get your turbo rebuilt? I talked to Alamo and they are about $450 for mine!
93 White RS- BPT Built not bought!!
Worklog: viewtopic.php?f=46&t=78988
Alamo is the only place in the city that does turbochargers. They mostly
do huge trucks. 450 is pretty standard for a rebuild, they do the whole
unit though so its quite worth it if you have any doubt about the health
of your turbo. Warranty too.
1994 MX-3 RS
- WhiteFinish
Looking badass that turbo
1994 MX-3 RS
- RS_OBD'oh_2
Step one: Pull tranny
Step two: Insert Mike
This is the last road block. That's it... I've had enough. She needs to be broken in.
kyser182
You are awesome!
Wish I would of gotten in to cars at a younger age.
You have a ton of ingenuity and it is great to see!
1993 MX-3 GS
- Evo_Spec
hey you went out and got a engine support! it really helped us to get under the car, looks like it came in handy for you too!
so did the speedo gear do any damage? or are you gonna be able to put your tranny back in without rebuilding it again like you were talking about.
Awesome update, gave me quite a laugh. i would definitely like a ride in your car when you get it all done.....again lol =)
RobMinhas
The last update was the most well articulated, comical and awesome post on this site. One of the best uses of rage faces I've ever seen.
- Evo_Spec
so what's going on with this? i assume it's back together and running?
Yeah low boost is tuned, waiting on tuner to return from the states to finish high boost.
Havent seen dyno numbers but im told its way better than before. Butt dyno is meh cause
it stops after 8 lbs
1994 MX-3 RS
Traction?
1994 MX-3 RS
- Tavman_1213
So clean mike!! I hope to be able to drive with you by August 1st!!
