weede`s KL-ZE Supercharger - Megasquirt
mx3matt
Re: weede`s KL-ZE Supercharger - Megasquirt
Post by mx3matt »
amazing job on the outlet, but i still think you should clearance the lower rad support.
Thefez
Post by Thefez »
I absolutly love this car with a passion truly one of my favorite MX-3's on this site...
where did u get that piller with the pod?
weede_klze
Post by weede_klze »
youdirtyfox wrote:Will that not contact during engine movement?
if will , i can take off some of material :)
BTW
i relocated power steering cooler (will be intercooler instead) and fit much bigger cooler from mazda 626
weede_klze
custom made water cooler (two times wider and 10cm less than stockk)
Intercooler on board
i want keep sleeper style
mooore coolers
kulluminati777
Post by kulluminati777 »
lol your power steering fluid gets that hot. I want to do the same but use it as an oil cooler. You said you got it from a 626? Or is it an aftermarket thing. did you cut the chassis any or it all fit behind the bumper just fine? Does look good BTW
weede_klze
no i dont want to cut chassie - only bumper was cut. Power steering cooler is OEM Mazda from 626 but i dont remeber witch one. Of course this power steering cooler is little exaggerated but why not ;)
Thefez
Post by Thefez »
any updates on this man?
weede_klze
unfortunately, the engine was broke :( One night two ZE retainer cracked and when my friend started to fix it I saw little marks on bearings causes of lack oil...So i now finish rebuild engine with KLDE valves/retainer (much stronger than ZE) and with reconfigurated oil relocation kit. I hope it will help, i lost this season :(
posey92
Post by posey92 »
Love the supercharger...ill be doing the same but I have an M90 from the Ford Superbird. Havnt done the math yet. But im all about the budget. Ill figure out what ratio to get what psi I want then find some cam gears at the yard the size I need. Instant cog drive. No chamce of slipping.
M90 is pretty big...
weede_klze
M90 only in battery place
Even then, just for it's capacity, it's for a larger motor, 3.0 to 5.0L. My truck is a 3.3 with an M62
weede_klze
Car back on street :)
I have intaled KLDE retainers and springs.
Spring Set:)
- new gear selector
- OEM rubbers and screws for gear selector
- 10W60 Oil + OEM filter
- poli on the back
- SACHS cover for struds
Rear Tokico HP struds.
I thing i dont send this photo...Air filter for Supercharger
kulluminati777
YESSSS!!!!!!!! very cool i love its back on the road. What intake is that? I want to use a straight neck as well but im not 100% sure I want to relocated the battery just yet....
Thefez
Post by Thefez »
would love to see some pics of the supercharger set up here how everythings installed
