1" or bigger Master Cylinder?
- [LVPA]93GsSe
Re: 1" or bigger Master Cylinder?
Knowing you've spent too much on your car,
yet, you still want to keep modding. -priceless
boosted_bullet
93 Honda Accord LX - Wrecked
95 Honda Del Sol Si - Stolen
92 Honda Accord EX - Parted out
2000 Toyota Celica GTS - Cracked block and broken differential teeth
93 SE - ATX to MTX, work as always in progress
01 Toyota Celica GTS - DD
Worklog to be up soon, still... ...
boosted_bullet
- [LVPA]93GsSe
boosted_bullet
boosted_bullet
- WhiteFinish
So did the MC just fit into the brake booster ? No changes ?
What kind of intake are you using ? K8, KLDE, KLZE curved/longneck ? Did you hit anything with the fluid reservoir?
- [LVPA]93GsSe
That's right direct fit, no problem. I'm using a KLG4 straight neck and a KL47 TB. I had to do the usual grinding of the throttle bracket so it wouldn't hit the reservoir and I even took a very tiny amount off the plastic lip on the reservoir. I'm heading out to do something but when I get back I'll post a pic or 2.
boosted_bullet
boosted_bullet
- [LVPA]93GsSe
boosted_bullet
boosted_bullet
- Josh
Yeah they are the same externally, minus the lines being on the other side. Just the inside has been bored to 1". I had heard rumors that the rod was different but figured it was due to the car chassis differences.
- [LVPA]93GsSe
I believe all I had to do was adjust the rod, after it was in.
boosted_bullet
boosted_bullet
- WhiteFinish
- Josh
Nope not on these ones. there is a bucket with grease for the end of the rod.
gerald_23
Awesome thank you for the pictures
- WhiteFinish
- [LVPA]93GsSe
I'm not sure about the inner seal, I honestly didn't notice, but I haven't had any brake problems since it's been in.
And it looks like you have ABS, I'm not sure if it's any different, but I don't have ABS.
boosted_bullet
boosted_bullet
- [LVPA]93GsSe
@gerald_23
Sorry I missed your thanks, your welcome.
boosted_bullet
boosted_bullet
The seal on the millenia and GS booster are the same. Myself and a few others have swapped in a MX-6 booster, which has to be modified to get the GS master to fit and an alternative sealing method has to be sorted out. That may be where your confusion is coming from.
- WhiteFinish
Still don't understand what part you had to adjust. Could you explain once more?
