Marc's S2- Autozam AZ-3 B5ZE -BOOOOOSSST videooooooo
- AaronTietje
Re: Marc's Sooty 2.0 - Autozam AZ-3 1.5 DOHC
Great project. Just make sure you cover all your glass before you start welding.
- marcdh
I've started the patching in of the aerial battered section today.
Will hopefully finish that tomorrow. I've currently got it tacked in place. TIG welders are awesome
View Worklog
View Worklog
JayoM
Saved and used? This thing was a daily driver man! But yeah, delighted that Marc is gonna expand its potential. I'll have to head up for a spin once its turbo'd!kulluminati777 wrote:oh man u have a journey ahead of you lol. But it is cool to see another MX saved and actually used
- marcdh
Haha you're welcome to Jason.
I have to say I'm not a fan of bodywork! So tedious.
Welding done.
Etch primed after metal filler
It's pretty close now in terms of finish. I'll hopefully block sand once more, then filler primer, then paint. Can't look worse than it did
Welding done.
View Worklog
View Worklog
take the tube from a can of WD40 and put it in your primer nozzle. Get inside the opening with it and spray the back side of those welds as best you can. The rust will come through quickly from the back of the welds if you don't seal it.
Looks like you're better at welding sheet metal than I am. Well done.
- marcdh
Thanks for the tip Charlie. Will do! I used weld through primer but still makes sense to cover the welds. I'm going to shove a vacuum down there too and try and suck up all the filings. Already did my best with a magnet.
View Worklog
View Worklog
- marcdh
Did a bit more sand fill prime today. Still got more to go. Getting those edges flat but curved is the worst bit.
Anyway, whilst waiting between drying I familiarised myself with the engine more.
B6S7 Cams
B551-7 Head
Looks like a BP valve cover... yet smaller!
B6 Pattern exhaust studs
Heads look pretty clean, mileage seems believable! I'm going to change the valve cover gasket after I clean up the valve cover. I'm impressed by the chromed bolts as standard! Next up oil change.
B6S7 Cams
B551-7 Head
View Worklog
View Worklog
- marcdh
Done for now! That was some ordeal. Bodywork is so slow. I'm happy enough. I can't really find the weld anymore
BEFORE:
AFTER:
Both of these have been tackled now, pics to follow, new setup:
-x2 new ball joints (boots were destroyed)
-x2 new tie rod ends (boots were destroyed)
-mazda 323f BA lantis v6 spindles
-mazda 323f BA lantis v6 5 stud hubs
-mazda 323f BA lantis v6 brakes and discs
-goodridge SS brake lines
BEFORE:
AFTER:
View Worklog
View Worklog
- marcdh
Windscreen replacement booked for Monday
Soon be ready for MOT and import registration
View Worklog
View Worklog
- marcdh
Probably going to swap my carbon fibre bonnet over anyway but anyway - before on RHS, after polishing on LHS:
MX3 to 323F BA V6 5 stud
BEFORE 257mm disc, 54mm piston, 4stud:
AFTER 274mm disc, 57mm piston, 5 stud, goodridge SS brake lines:
Also replaced tie rod ends and ball joints due to split boots.
Windscreen out!
Windscreen in!
Front bumper swapped over with glass headlights, clear sidelights and you can see the polishing has helped this side a lot
Windscreen out!
Windscreen in!
View Worklog
View Worklog
- AaronTietje
Re: Marc's Sooty 2.0 - Autozam AZ-3 B5ZE -New windscreen&5st
Gread job on the body work; it looks good.
- marcdh
Thanks Aaron, it's getting better anyway! I still fancy a summer cheapo DIY respray but I'll see how it goes.
New window certainly smartens things up
View Worklog
View Worklog
- marcdh
BEFORE:
AFTER:
Nice MAF system on these, very little restriction compared to the V6 VAF. External IAT sensor too, nifty!
Now with K&N cone filter
Windscreen looks fantastic
The seal is really neat, glad I went new.
Also:
Ran wynns engine cleaner, largely cleared up sticky HLA tick
New oil filter
New oil
New valve cover gasket
AFTER:
Also:
New oil filter
New oil
View Worklog
View Worklog
- marcdh
Mazdaspeed strut bar installed, plenty of clearance on a 4 cylinder
View Worklog
View Worklog
- WhiteFinish
Forgot you had it !!!!
Definitly add's good bling ! But if you forgot.. did you also forget you promised to sell it to me
