Stumbling
- mitmaks
Re: Stumbling
Well, what I did is pull off disty cap and spray outside/inside with WD40, sprayed connections to disty, put dielectric grease on spark plug wires, inside disty cap. It still was stumbling at times, then I've ran some red bottle IsoHeet and so far I haven't had problems.
- mitmaks
Re: Stumbling
Issue came up when I was driving on highway back in May. I later took a look at it and my rubber intake boot (accordion pipe) had a slit in it. Wrapped it real good with electrical tape and now it runs great again.
- [LVPA]93GsSe
Re: Stumbling
I had been lucky with that pipe, while I was using it, with no issues but that is know n to happen. Good to hear it was something easy to solve.
Knowing you've spent too much on your car,
yet, you still want to keep modding. -priceless
boosted_bullet
93 Honda Accord LX - Wrecked
95 Honda Del Sol Si - Stolen
92 Honda Accord EX - Parted out
2000 Toyota Celica GTS - Cracked block and broken differential teeth
93 SE - ATX to MTX, work as always in progress
01 Toyota Celica GTS - DD
Worklog to be up soon, still... ...
boosted_bullet
