Dan, I'll probably cut the wiring for the plugs themselves, and worry about pulling the connectors when I get the engine home.
Alternator rebuild
- MrMazda92
Re: Alternator rebuild
Everybody loves getting a unique haul from the junkyard, when we're lucky enough to do so!
I'll be able to take my time with it then, since I'm already tearing into it anyways.
- Josh
Contact Romaine Electric http://www.romaineelectric.com/page4.html there is one in Wenatchee
I just rebuilt mine yesterday, they had all the parts on the shelf.
- mitmaks
Millenia alternator is 90AMP just like mx-3 isn't it?Demonic1 wrote:Junkyard Millenia alternator, millenia rebuild kit.Nd4SpdSe wrote:Why not just swap for the Millenia alt?
Higher amp and probably better reliability.
The mitsu units are garbage. (And one of the next peices I'm swapping out)
Demonic1
The KJ and KL had 110 amp alternators in them.
92 RS BP05
93 GS KLZE
92 RS BP05
93 GS KLZE
Earlier Millenia's had the 110, but apparently they went down to 90amp in the later years...
- MrMazda92
This is true... I've found three 90 amps and one 110 so far.Nd4SpdSe wrote:Earlier Millenia's had the 110, but apparently they went down to 90amp in the later years...
- Josh
They only went to a 90amp in like one or two years of production. I pulled mine from a 00'. I want to say 97-98 has 90amp.
