want to do the Klze swap
Re: want to do the Klze swap
SuperK wrote:whitete, the best way to up your post count is to post animated smileys singing/dancing/etc
No, you see, the trick goes as such:
1) Post a good reply, show you're not some spammer and you actually know your stuff and are a contributing member of the site. It'll give your post count some meaning, some weight, where your reputation actually gets multiplied by your postcount (Rep = Rep x √PostCount).
2) Once that's done, odd and pointless posts that follow really don't stand out as irrelevant spam
3) Using long winded replies that sound intelligent make the useless point sound good and relevant, regardless on how off-topic it may be.
3) Rather than quoting and put everything in a single post, do multiple quotes as multiple posts, it really brings up the post count
4) Put in errors in your post. People here like to nit-pick than harass, comment and reply on it. It helps distract to the spamming. It also encourages addition responses to their replies. The more the thread gets off topic, the more and more you can willingly spam and get away with it.
5) When threads get into multiple pages, your responces get broken up so your attempts to post whore get that little less attention
:2thumbsup:
Post by wytbishop »
whitete wrote:sorry guys they are right about all axles are the same minus the JDM LSD transmission.
and i thought most here did do the 5th gear swap - sorry -
and i need to make more helpful hints and tips and post more topics that are meaningful to make my post count higher - over 53 - mabey if i had over 1000 id know more about the mx3 .
ive owned 5 mx3's so far and swaped out 3 of the k8 engines for KLDE's
and my current DD was daninskis red KLZE that he swaped
wytbishop (sorry) for not being so helpful - i mean thats why were here
and Nd4SpdSe
thank you for the clarification about the axles i dont want to give false info to other memebers . just it was to my memory that there were two types of axles offered not just stage 1 2 3 etc..
Don't take it personally man. I've been here a long time and I've seen a lot of newcomers offering a lot of bad advice. Based on your comments, it appeared that you might be another like that. If you're not, I appologize.
whitete
Post by whitete »
none taken guys ive been here for a while and on here daily , i read what others post and take it to heart.. thanks for the tips
Red96'Mx3 KL-ZE 2.5, CAI, full 2.5'' exhaust,cat delete, black stock rims polished lip, cross drilled brakes, (aftermarket bumper with halo foglights-Needs work) .
http://www.cardomain.com/id/whitete
Previous rides
Purple94' Mx3 K8-ZE CAI, Exhaust, plugs,wires
Purple95' Mx3 K8 american, CAI, Exhaust, plugs, wires,cap/rotor fuel pump, short shift,
Black 94' Mx3 i4 Stock ( hit by dear )
