Help with passenger side CV Axle!!!
Re: Help with passenger side CV Axle!!!
Why not just rent an axle puller. It's so easy that way. I've tried pushing the axle in then snapping it out and have had luck doing that. Anyway axle puller man, axle puller. If you remove the bolts for the intermediate shaft you may open up a can of worms if the threads are corroded. You may then have to tap the threads out.
