Re: JUST got a K8-ZE
Posted: July 4th, 2010, 6:25 am
To remove the engine pulley I always out a crow bar and start the car up and it comes loose. This only works with engine installed of course. Why are you removing the pulley?
The Worlds First and Largest Mazda MX-3 Forums
https://www.mx-3.com/phpbb3/
Where did you get this information? Cause I can't find any Eunos Presso/30x that makes that kind of power. All information to 1997-98 lists it as having 99kw (~135hp). Personally by the way you're talking it sounds like you don't have all your ducks in a row and are making assumptionsmikeetown wrote:In-case you didn't know,
A K8-ZE can! output 144 hp. The only problem is, you need to have a 1994 and up Mazda mx3 because you need OBDII in your car. Also, you need an ECU from a Japanese 1996 and up mx3 (Uenos or whatever it is), then you can output that amount of power. Stock, a K8-ZE with OBDI and an original ECU will output 135HP at 6600 rpm approximately because of a higher redline at 7500RPM and probably cause of a few other minor differences. It pretty much is a K8-DE but with a more advanced ECU controlling it.
i hope that clears questions. I researched it on here and around the internet. If u have a j-spec 1996 + ecu tell me cause i want one.
Sounds like you're posting assumptions rather than facts. Those links you mention would be really nice to have.mikeetown wrote:I've been reading on this stuff since November 2009 when i bought the car. I put info from this site and others together after all this time. It just is a lot of work to make a K8-ZE do 144 hp. Doesnt it make sense though;
-ECU from newer mx-3 with more refined settings flashed in
-OBDII to send more refined settings to the engines management
-K8-ZE being altered a bit, having a 7500 rpm redline which probably means it can take in more air. The newer computer probably has better fuel : Air ratio's dialed in.
There might be other things too though. Having no catalytic converter might not have been mentioned when i was reading through. I know this makes a significant gain in all around performance. If you don't agree then try this yo your car. When air care re certifying comes i just bolt my CAT back on.
If i can, i'll post the various links when i run into them, on this discussion. I read interesting articles on this a while back.
No its as u said in your 3rd paragraph. You need EVERYTHING!! which makes it not really worth it for 9 more hp. Some of my stuff are assumptions and some i read in the last year. BUt the stuff i read can also be assumptions from other ppl so lets just say................ when ppl read this topic there will be less confusion and assumption.Nd4SpdSe wrote:Sounds like you're posting assumptions rather than facts. Those links you mention would be really nice to have.mikeetown wrote:I've been reading on this stuff since November 2009 when i bought the car. I put info from this site and others together after all this time. It just is a lot of work to make a K8-ZE do 144 hp. Doesnt it make sense though;
I'm not sure if you mean you're modifing it to make 144hp or tune it to the factory "144" specs, but like I said, I can't find any information saying that the mx-3 made 144hp in stock form.
Indeed as RS said, you have to convert your car to an OBDII Mx3 to accept the 1996+ ECu's, so you'll have to change your wiring harness, which includes extra 02 monitoring sensors. If you want your car to make this "144hp", you need to have EVERYTHING that's part of that system, intact and working.
Secondly, you can't flash an OBDII Mx3 ECU. Yes, it's a much smarter system, but not tunable or programmable.
