yep the ebay clutch lasted 3 months on the zeNd4SpdSe wrote:In other words you learned the hard way....johnmx3ze wrote:i did that too i bought an ebay F1 racing shitt and now i have a bully stage 3 and i love it...hgallegos915 wrote:I sure did... but it was not a good pof a clutch that I tought it was. I think it was a knock off version.. thats what I get for going the cheap way the first time..
New record KLZE turbo at the track!
- johnmx3ze
Re: New record KLZE turbo at the track!
mx-3,  KL turbo (tooo much to list) yeah its boosted!
				2RotorsNaDream
Heres my advise, go get a nice ACT 6 puck with the Xtreme PP and keep your stock flywheel. My car is now at 364whp after the latest tune and addition of my midpipe and the clutch doesnt skip a beat no matter what I do with it. Lightweight flywheels are fine all motor on the MX but with a turbo ZE its just gonna climb the revs too fast for your tires to keep up. Also, last I checked NT01s are pretty good tires, not slicks by any means but definitely not the reason for 15 second ¼ times and 2.4 60's. I think your car really needs the clutch badly and the driver mod   And try lowering your tire pressure.
 And try lowering your tire pressure. 1993 Mazda RX-7 Touring Edition Innocent Blue Mica- Not stock...
1993 Mazda RX-7 Touring Edition Innocent Blue Mica- Not stock...1993 Teal MX-3 GS- KLZE and other goodies. RIP
- Shades
hgallegos915 wrote:Yeah new record for SLOWNESS...
WTH!?
I ran consistant 15.1 and 15.2...
This track is ALL concrete.. My tires were worthless (nitto nt01) 15 inch.
and when I baby 1st gear it still slips.. it start grabbing by second gear.. Im going back next week with my stock 17 inch street tires and see what happens.. I was hoping to at least break into the 14s...
How is switching to a lower profile tire gonna help your launch?... you're gonna get even more wheel hop with 17's than 15's.
"Do it ONCE, do it RIGHT!"
				hgallegos915
I got a 15.2 with my bigger profile tires.
I had a 15.1 with the smaller tires.
The driver mod needs some work.
-hec
				hgallegos915
Just letting you all know, the main seal is bad and was leaking oil to the clutch.
the fidanza surface is all slick.. so i jjust ordered a replacement and I already received my clutch.
-hec
				mazdamx3freak
Well considering a K8 will slip like mad with gear oil on the disk, I would say theres most of your problem.
Yeah you deff had a problem, but if you were spinning you need some work on your driving, i got consistant 2.0 2.1 on full pressure street tires. even got a 1.9 once.
							1996 MX-3 GS - rollin' on Rota Slipstreams, (Red, Deep Tint, Black Lip)
True Straight Neck KLZE with TB relocate. Custom Cold air Intake. 2.25 Exhaust to Bosal muffler.
ACT Stage 2, Fidanza Lightweight Flywheel, Short Shifter with CorkSport Bushings and SS Clutch Line.
Suspension Techniques Springs On Zx2 Struts. SRD Control arm Bushings, Custom Sway Bar Links
				thebonestockkid
Trap speed @ 93mph... I'm curious as to what whp showed up on the dyno.
							 '97 Grenada black pearl Acura EL, JDM B18C 98spec ITR Swap. Power in Control full coilovers going in next spring. Not to mention a most unusual whining noise... coming soon.
'97 Grenada black pearl Acura EL, JDM B18C 98spec ITR Swap. Power in Control full coilovers going in next spring. Not to mention a most unusual whining noise... coming soon.'92 Intense blue pearl Jeep YJ, OME lift, mudders, fun.
R.I.P.
'93 Clear white GS-DE ~14.648@92.98mph, 2.234 60ft. PARTING OUT PM ME.
