Page 2 of 2
Re: NEW solution to front Swaybar endlinks found!!!
Posted: October 4th, 2008, 4:28 pm
by MX3ak
100% metal is sure bether than 50% metal, 50%plastic of aftermarket ones.
I got mine only 2 years old and sounds allready ruined.
Posted: October 23rd, 2008, 7:03 am
by projectmx
i'm confused you say they are bolt in like stock but these look only half like the stock ones... did you drill a hole into the front control arm to connect that part of the link up? or was there a hole already there? (i haven't looked closely at my CAs in a while so i can't recall offhand)
Posted: October 25th, 2008, 6:21 pm
by mazdamx3freak
projectmx wrote:i'm confused you say they are bolt in like stock but these look only half like the stock ones... did you drill a hole into the front control arm to connect that part of the link up? or was there a hole already there? (i haven't looked closely at my CAs in a while so i can't recall offhand)
sorry I wasnt clear, there is a predriled hole already there. b/c the 323, protege endlinks bolt through there.
Posted: November 12th, 2008, 9:54 pm
by mx3autozam
wytbishop wrote:I am a little biased, obviously, but the big problem I have with stock replacement, and the reason I decided to build and sell the spherical bearing end links, is that they were nearly impossible to get off. Once they've had a few years to rust and corrode, they are very hard to get off. I also wanted something more rigid.
but for $20 this is a good alternative.
more info on the spherical bearing links you are selling please!!!
Posted: November 12th, 2008, 11:24 pm
by IMACHU2
Very cool and very timely! (I am rebuilding my Suspension currently). So I wonder what 240SX rear end-links look like?
Posted: November 19th, 2008, 3:59 pm
by wytbishop
mx3autozam wrote:wytbishop wrote:I am a little biased, obviously, but the big problem I have with stock replacement, and the reason I decided to build and sell the spherical bearing end links, is that they were nearly impossible to get off. Once they've had a few years to rust and corrode, they are very hard to get off. I also wanted something more rigid.
This thread contains the information you seek. I will be doing another round in a little while. I have a little too much going on right now.
Posted: February 13th, 2009, 11:53 pm
by Inliner
Better yet:
$6.57 each off Amazon....
http://www.amazon.com/Beck-Arnley-101-4 ... 169&sr=8-2" onclick="window.open(this.href);return false;
