95-97 Kia Sephia in North A. . It's probably going to be called something else in N.Z. The best thing you can do to any internal gears is make them smoother via some finishing process. Knowing what and what not to smooth out is import. In a G series, I've noticed the biggest wear on the clutch hubs on the primary and secondary shafts. They have small teeth, top and bottom that mesh with the gears, either 2nd or 3rd gear as well as 4th and 5th. It is important to know that synchros will not wear like 2 hard pieces of steel clashing together. Synchros are a softer alloy metal.kiwi_MX3 wrote:the F serise are like glass and break real easy.
Im interested in what model of kia you have taken the axles
and gearbox parts from as i constantly strip third gear
The Kia trans is the best thing going right now for those that have BP engines IMO.
