KL Engine Internal Upgrading (Please Sticky so I can edit)
- XxantwawnxX
Re: KL Engine Internal Upgrading (Please Sticky so I can edit)
ok i see thanx alot.
I have a question on the cam's I am building a KL-ZE i am changing everything and then superchargeing it. But on the Gude.com the cam's they sell for a mx-3 v6 is that for the 1.8 or would that even work for the KL plus the specifications on the cam is that the same or would it be better?
1994 toyota supra single turbo
1994 Mazda MX-3 KL-ZE
If god owned a car... It would be a supra!!!
- Dragyn Vyrus
those pacesetter headers will fit the KLZE??
the 2.5 v6 probe ones that is
and can that site be trusted too or will i end up getting screwed over...
93 MX-3 ZE-GS - Sold
95 MX-3 RS - Bone stock winter car.
92 JDM turbo MR2 - SSQV, Cusco strut tower bar, ATS intercooler kit, Berk Exhuast, HKS EVC-S
will a MX6 2.5v6 clutch fit a K8 MX3 without major custom work ?
K8 :: 136.8 bhp---160 nm---108.0 whp---118lbs/torque
ET: 15.567 @ 136 kmh (84 mph)
"Racing a Honda is like being in the special Olympics, you may win, but in the end your still retarded."
Mnemonic
transmission question, clutch is not an internal part of the k series engine.
The question to your answer is Yes, there practically the same transmission.
Search
Search
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
thanks mnemonic ... and sorry for the mistake.
I think i am going to order a new clutch
You can now add ARP head studs as well. Kit number is 218-4704, which contains the studs, nuts and washers and they are available now apparently.
Thanks to Probetalk member Ausloki for harassing them long enough to actually produce a part.
'90 Mazda 323 - V6 KLDE, supercharged, right-hand drive, build log
'93 Ford Probe GT - a few mods... 10.24 @ 139.5 mph [20 psi] - 545 whp, 490 wtq @ 21psi
1997 Ford Probe GTS (Hybrid) - RWD Conversion - Build Thread
- MrMazda92
It's a bot... that sells runescape gold, and actually posts useful(if blatantly obvious) information? Where do people come up with this crap...xiaowanzi wrote:I'd assume with ferrea (like interprep) the idea is you replace all 24 exhaust and intake springs, then use 24 of their same size retainers and springs.
- MrMazda92
I would call you an idiot for trying to say K8 pistons = KL pistons, but you're a bot so I guess I'm the idiot for replying... Ryan, do you have ban power?danielmartin wrote:Ah, indicating that the probe or MX - 6, but with the KLZE, K8 platform, K8ZE and KFZE compatible set KLDE. For like the camshaft, crankpullys, crankshaft, connecting rod, piston, valves, there are mostly internal engine parts such as most from the KLZE engine.
- Ryan
Fixed
Up for updated links?
