Millenia Altenator (IG)
- slimmyslim1420
Would the K8 bracket not bolt up to your engine? The millenia bracket and K8 bracket bolt up the same they are just a little different for the part that bolts to the altenator. If you did get the K8 alt on you should probably be able to put the millenia one on too. If you had asked me a week ago I could have given you a good pic of the millenia bracket but now its in the car so its not so easy. I think the years range from like 95-98 though I am not 100% sure, you could always call a parts store they could tell you which ones would be 110amp.
1992 GS ZE swap 94 dash swap drilled and slotted rotors full ceramic pads CS SS clutch and brake lines KL-36 ecu zx-2 tokico struts eibach springs short shifter Tenzo exhaust Hi flow cat 2.5 in piping
- ryanlindenberg
i don't know what the k8 bracket looks like either. i've only seen the bpt and the b6 one. the b6 bracket wouldn't bolt up to my bpt. did the millenia bracket look similar to the ghetto one i drew?
CARDOMAIN WITH UPDATED PICS
