If your worried about the tunningfry_81 wrote:you wouldnt want high compression pistons if you were running a turbo.Juans_93_MX3 wrote:bore and stroke, custom high compression pistons/rods and port and polish then I
Other than that, if you want power you should go for high compression pistons
