How-to nissan injectors and modded rails
babyblueMX3
Post by babyblueMX3 »
oh-hell wrote:With an fmu is it nessasary to do the injector mod?
with an fmu, you just bump the fuel pressure with boost. But there's a time that come when the stock injectors aren't able to give you the flow you want. This is when you need to upgrade them for some like that.
RIP 400whp ZE-T MX-3
Steeb
Post by Steeb »
has anyone flow tested the stock fuel rails to find out the largest injectors we can run before there is fuel pressure difference between injectors?
ive been searching for a while but i cant find anything on it. running injectors larger than the stock fuel rails can flow will also help u blow your motor quickly cuz one or more cylinders will run lean one day and poof, investment wasted.
does anyone know if mbx motorsports offer aftermarket fuels?
babyblueMX3
probeaddiction was working on one. Not sure if it's out yet
PWRD_BY_HKS
Re: How-to nissan injectors and modded rails
Post by PWRD_BY_HKS »
Okay you said to use the connectors that come with the injectors right. So then you just splice or......?
jdmx-3 KID OF THE Image
VICTORIA RACING
ZE PERFORMANCE IN 915 TX
Kl01-ZE,Kl31 ecu, millenia manifold, ngk plugs, ngk wires, probe tranny/ and clutch (stock), VortecH FMU 12:1, Aeromotive AFPR, Tial .38mm Wastegate w/ 4lbs spring, Walboro 255 pump, AiResearch T4, 3" down pipe, GODSPEED manifold, Spearco Boost Gauges, BF Goodrich G-force drag radials.
14.8 1/4 mile all motor untimed on boost.
solo_ryder
Post by solo_ryder »
This thread is old, you would splice the wires into the oem harness
Demonicdst
Post by Demonicdst »
is there anyone on the forum who can do this injector up grade for some money or and kind of a group buy somewhere cuz im not like 100% able to build something like that currently
http://www.cardomain.com/ride/2971181" onclick="window.open(this.href);return false;
BIGLOU_MX3
Post by BIGLOU_MX3 »
What if u did the ''trick'' to stock k8 injectors, What would u get cc wise??
92 MX3 GS- PACESETTER CATBACK,COLD AIR INTAKE,SHORTTHROW SHIFTER, PHAT TIRES, AND STILL MODDING
Isn't there an issue with the actual spray pattern of the modden Nissan injectors?
short4stuff
Post by short4stuff »
Just want to add. As far as I know you can't run these using the stock ecu. Meaning you can't just add these if you have an fmu. You need megasquirt or someother standalone.
EZ_4_FUN
Post by EZ_4_FUN »
Nd4SpdSe wrote:Isn't there an issue with the actual spray pattern of the modden Nissan injectors?
Yes, the "super soaker" effect. You get a stream of fuel as apposed to an atomised spray.
I used the factory injector hats which have a knife edge to them to help with this issue.
OSKY
95 MX-3 GS ZE Turbo: MSnS-extra, AEM WB, Blitz boost controller, MSD 6A w/ Blaster2 Coil, ZE disty, Redtops @ 550, Walbro 255, Garrett T3/T04E 60 Trim w/ .63 A/R, 38mm Deltagate Mark II @4psi, FMIC, Apexi BOV, CM Dual friction, 4-6.25 Kickers, 2ch Alpine V12. That's Alll.
http://www.pakfeifertuning.com
Flinch
Post by Flinch »
Only thing this writeup could use is a wiring diagram or a link to one, it may be on the forums but its nearly impossible to find. These injectors are so simple to do, but plug N play is always the best.
-KL31 stock internals with curved neck intake manifold and KL36 ecu
-Turbo running 7.5psi
-FMI 3"x12"x32" all alluminum and welded, have a 7.5 PSI spring she just creeps on cold nights
-ACT 6puck sprung/96 probe tranny
-Short shifter
-HEI and MSD 6al (makes a big difference when you spend the 65$ ont he right spark plugs)
-KYB GR-2 struts with H & R springs
-Megan racing seats
-Personal 280mm stearing wheel
-Familia rear strut tower bar
mx3autozam
Post by mx3autozam »
Photobucket is being gay now and doesn' show pictures after 90days of inactivity.
93 Mazda MX3 KLZE Turbo
johnmx3ze
Post by johnmx3ze »
im currently getting info on how to do the modded nissan injectors and i pretty much got everything but the wiring!
can someone help me?
tehbrookzorz
Post by tehbrookzorz »
Just want to mention I saw mbolin is doing a final GB on Probetalk for modded rails.
Cody
johnmx3ze
Post by johnmx3ze »
yeah i know but dont you think it would be cheaper for me to get it done at a local shop?
i have no idea how much that could cost!
Return to “Forced Induction”
