My brakes failed on me today (Why?)
quicksliver
Post by quicksliver »
You guys have any tips/tricks on how to loosen what seems to be a rusted shut bleeder screw without snapping it?
neutral
Post by neutral »
Have you tried PB Blaster, great stuff and available at most autoparts stores.
Image -Jim
Gro Harlem
Post by Gro Harlem »
^^ that sh1t sux....
use rust-eater, cheaper & smells goooooooooooooood
DONATE TO MX-3.COM
neutral
Post by neutral »
Is "rust-eater" the actual name of the product? Is it that Starbrite stuff, RX-5 or Novirox? Gotta link? I got mixed results w/a Web search. Thx.
Image -Jim
schuttie2002
Post by schuttie2002 »
I use marvel mystery penetrating oil from pep boys. It works like a champ, on everything ive needed it too
jschrauwen
Post by jschrauwen »
Heating area with propane torch beside bleed screw while keeping bleed screw cooler may work too. Just a guess though.
Kokiriwave
Post by Kokiriwave »
make sure all the lug nuts are tighted...
I had the same problem as you described, checked the wheels and found two lug nuts missing off the front passenger wheel.
I want MAZDASPEED!
MY WEBSITE:: http://kingmx.net
