Page 2 of 2
Posted: July 14th, 2005, 1:01 pm
by Insanebabe123
Get a 12v photosensor wire it up after the switch. Leave the switch in the on position and move its power source to a position that only comes on when the car is running or is in accesorry position. This way you can manually override the sensor if you want.
Dad told me this, cause now I am thinking about it as well.
Posted: July 14th, 2005, 2:35 pm
by MX3-Freak
Dominicanchu_Nmbr1 wrote:if it was up to me, i'd have everything manual. no electrical issues to worry about.
Crank start?
Posted: July 14th, 2005, 8:37 pm
by Dominicanchu_Nmbr1
thats a little too manual, but i could use the excersice... hmmm...
Posted: July 14th, 2005, 8:41 pm
Insanebabe123 wrote:Get a 12v photosensor wire it up after the switch. Leave the switch in the on position and move its power source to a position that only comes on when the car is running or is in accesorry position. This way you can manually override the sensor if you want.
How about wiring it to the radio? Will that work?
by Tunes67
Might as well cut out your floor boards and fred flintstone it around town
Tunes67
Posted: July 14th, 2005, 9:02 pm
by Grants
But you will only be able to manually override it to the OFF position. You need to be able to override ON as well. What happens if your in a bright car park or tunnel or something? Your lights will go off and you won't be able to turn them on. Not the best way.....
