What's your favorite brand of drag/Race tire and why?
- PWRD_BY_HKS
G FORCE BF GOODRICH
							jdmx-3 KID OF THE
VICTORIA RACING
ZE PERFORMANCE IN 915 TX
Kl01-ZE,Kl31 ecu, millenia manifold, ngk plugs, ngk wires, probe tranny/ and clutch (stock), VortecH FMU 12:1, Aeromotive AFPR, Tial .38mm Wastegate w/ 4lbs spring, Walboro 255 pump, AiResearch T4, 3" down pipe, GODSPEED manifold, Spearco Boost Gauges, BF Goodrich G-force drag radials.
14.8 1/4 mile all motor untimed on boost.
VICTORIA RACING
- PATDIESEL
Kumho 710s or Yokohoma A032R. The Falken are great, but are street legal race slicks. Great for Auto-X, but on the track I want a full race tire.
- cjthor
Re: What's your favorite brand of drag/Race tire and why?
Well now that I have had about 10 passes on my Mickey Thompsons......I love em!! ET Drags all the way!
							Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
- mitmaks
Got Nitto 555's on Cobra, its decent drag radial
							Magnum s/s lines, strut bars, carbon fiber bezel, indiglow gauge, Sony Xplod, inverted c/f hood, SRD lower tie bar '93 GS SE  '95 Cobra SVT #2722 '68 Charger R/T 440
i used my drag radial to the core this year, they're ok, but first will allways spin, a bit in second too...
i tried myckey thompson 15'' and they are JUST SICK, no wheelspin, even when declutching at 7k rpm
96 rs-t mx-3, 12.62@114
u have the Zoom Zoom feeling?
I used to run M/T ET Drag slicks (26x8.5x15), and they were good.  I switched to Hoosier slicks last year (drag racing, i should add) because they offered a slightly wider (9") slick in 26x9x15.  I like the Hoosier better, they require a much shorter burnout to get hot than the M/Ts.  They wear extremely well, and are a good FWD slick.  I launch at 5500 rpm and i've gotten the best short time/high speed stability combo at 5.5 psi air pressure.  I used to run the M/Ts at 6.75 psi.
							'90 Mazda 323 - V6 KLDE, supercharged, right-hand drive, build log
'93 Ford Probe GT - a few mods... 10.24 @ 139.5 mph [20 psi] - 545 whp, 490 wtq @ 21psi
1997 Ford Probe GTS (Hybrid) - RWD Conversion - Build Thread
- Shades
cjthor wrote:Well now that I have had about 10 passes on my Mickey Thompsons......I love em!! ET Drags all the way!
What size tire and what pressure were you running... I got the 24.5x8 on 15's. I'm assuming you had to run a tube too.
"Do it ONCE, do it RIGHT!"
				mattster03
Another good slick to look into for FWD drag racing is the M&H Racemaster.  It comes in some very friendly size and is bias ply in construction.  I'm a pretty big fan of ET drags as well
							1992 Mazda MX-3 GS
1993 Mazda RX7 R1, LS1/T56 Swap, 10.943 @ 130mph
http://www.cardomain.com/id/mattsterrx7
Re:
same here.nope-mx3 wrote:I`m gonna use Toyo R888 on 15`s for trackdays.
Drag is imho useless
nope-mx3
im trying to find some R888 myself, but they are kind of expensive here. Maybe going to try Falken's bet
K8 :: 136.8 bhp---160 nm---108.0 whp---118lbs/torque
ET: 15.567 @ 136 kmh (84 mph)
"Racing a Honda is like being in the special Olympics, you may win, but in the end your still retarded."
