Page 2 of 2
Posted: February 3rd, 2005, 11:17 pm
by mxmaz
Yeah just spray some carb cleaner all over it with the engine running, and if you hear a change in idle, that is caused by the cleaner getting sucked in and you know you have a leak.
Posted: May 26th, 2005, 1:11 pm
by shuan24
bump.
What is the resolution of this problem? I am having the exact same problem!
Fluxuating Idle????
Posted: May 26th, 2005, 3:44 pm
by mulisha631
:?: i have a v6 and when i first start up the car or rev the engin with the clutch in my idle will bounce from about 600- 1,500. could that also be the air intake or would it be my egr valve. i've also heard a misfunctioning egr could be the problem.... Any suggestions guys :D
Posted: May 26th, 2005, 6:45 pm
by jschrauwen
mxmaz wrote: BTW - did you test it to see if it was leaking?
Maz, how do you do your test...butane/water???
Posted: May 26th, 2005, 7:20 pm
by kiwi_MX3
Carb Cleaner or Contact cleaner, anything thats flammable
really John.. Cos the leak suck's it in and richen's up the motor
and idles higher..
Matt...
