Page 2 of 3
Re: new solid end links
Posted: June 30th, 2004, 10:39 am
by projectmx
i didn't see an actual price posted how much are they? do you know if they will fit a 95 protege also? they look very similar
Posted: June 30th, 2004, 12:06 pm
by babyblueMX3
they can be seen on here
cost was 65$ for all 4 if anyone wants them just drop me a line
that was the first post
Posted: July 1st, 2004, 10:34 am
by projectmx
not sure how in the world i missed that i flipped through the thread like three times real quick and missed it. sorry about that. but what about the first ? about them fitting a protege... any idea if they will? i need them for my gf's second gen also
Posted: July 5th, 2004, 5:39 am
by DJsMX-3
I occasionally have a very slight clunking when driving on uneven roads or when the front wheel in on of the sides "drop" into a pothole....
I dont think its my springs bacause if i drive fast while going over hills and such where they really get compressed theres no sound at all
Could this be the endlinks clunking???
Posted: July 5th, 2004, 7:57 am
by babyblueMX3
yup classic case..that's what ring the bell for me to check them...3 out of 4 were broke
Posted: July 5th, 2004, 1:52 pm
by DJsMX-3
Babyblue:So i just guesstimate that theyre the ones doing the clunking and replace them?? Or can i actually see pfysically on them that theyre broke?
I have been under the car before while having this problem,but the little rod between the two nuts werent broke/rusted over...
Posted: July 5th, 2004, 2:32 pm
by babyblueMX3
when i saw that mine were broke..the link it self wasn't broke but the bushing were (where the links connect to the tab) there was one missing too don't know how that happened though
Posted: July 5th, 2004, 2:44 pm
by DJsMX-3
Babyblue: Okay so if i get under the car again and take a closer look at those endlinks,and they "appear" to be fine then theyre not the cause for the clunking?
Posted: July 5th, 2004, 3:40 pm
by babyblueMX3
if they appear to be fix and solid then your problem will be something else
Posted: July 5th, 2004, 4:33 pm
by DJsMX-3
Okay thanks babyblue,so are theese "solid" endlinks better/cheaper than original mazdaparts as it is with most other aftermarket parts?
And will i need to do lots of mods to the car to get theese endlinks to fit probertly?
Mainly my concern is if i can go back to original parts lateron,or is that not possible after having tryed theese on??
Posted: July 5th, 2004, 5:34 pm
by babyblueMX3
no modification what so ever to fits these..you can install back your oem if you want to...Biggest reason why I bought those was because they are indeed cheaper than oem..
if you want some contact tonguefreek on this board
Posted: July 5th, 2004, 5:57 pm
by DJsMX-3
Yeah i thought so,damn OEM prices
Posted: July 5th, 2004, 7:04 pm
by babyblueMX3
I can't actually see the difference because i went from didn't have any to those so I can't comapre with the stock ones
Posted: July 5th, 2004, 10:35 pm
by perhapsadingo8yerbaby
Agreed it does sound typical like could be the endlinks. A leaking strut cartridge seal can also cause the sound you describe. Easy enough to check too. Just do a visual inspection of the corner where the sound is coming from. Look for any sign of fluid on the outside of the strut. They should appear dry...
Posted: July 6th, 2004, 3:58 am
by DJsMX-3
Thanks for the advice perhaps,but the struts are quite new and all dry
Man i hope that its just those stupid endlinks,and not something else thats hard to locate or replace...
