Pictures of my Turbo Mazda MX3
992mmx3
Re: Pictures of my Turbo Mazda MX3
Post by 992mmx3 »
Wow, it looks great, the color is awesome, and that front bumper is cool, why didn't the U.S. get those bumpers? Meh, oh well, good job on the car!
-Mark Lathrop
1992 MX-3 RS-T
B6T with some goodies
Is that a MazdaSpeed front bumper?
osargeant
Post by osargeant »
Nope, that is a standard JSpec front bumper that came on some Mazda MX3 sold in Japan.
JSpec Turbo MX3 (1.6 DOHC)
http://www.cardomain.com/memberpage/310985
Port and Polished Head, Ported Intake Manifold, Valve Job, GTX Manifold, Hybrid Turbo, Cone Filter, 2.5" Exhaust, 2.5" Downpipe, ACT Street Clutch, Lightened Flywheel, MSD 6A Ignition, Boost Retard and SS Coil, Magnecor Plug Wires, Denso Iridium Plugs, UR Lightened Pulley, Spearco FMIC, Turbo XS BOV & MBC, BEGI RRFPR, Supra Injectors, Walbro 255 Fuel Pump, Autometer Gauges, Pivot Shift Light
osargeant
Post by osargeant »
Well Guys,<p>I think I have blown my turbo, I am getting some white smoke coming out the exhaust when I am on boost and the car isnt pulling as strong as before. <p>Guess that happens when you run 9psi on an old IHI-VJ14 turbo :) <p>In terms of replacements, should I look at just getting another IHI VJ14 or would a VJ11 or VJ20 be a better buy.<p>Please advise.
JWMotorsports
Post by JWMotorsports »
White smoke usally means your burning coolant. If It was your turbo it would more than likely be blue smoke from leaky oil seals around the floating bearings. The other thing that usually happens when a turbo is going down hill is it gets laggier, less max boost pressure, & it starts getting noisy (like a BIG turbo). I'd recommend you check out your compression & make sure it's not your head gasket going bad!
osargeant
Post by osargeant »
Thanks for the info. <p>I do believe it is the turbo since it has gotten much noisier and there is much more lag. Also it is only boosting up to about 7psi these days.<p>The coolant level is actually fine which makes be believe that it is not the head gasket.<p>I will double check if the smoke is indeed white or blue.
BATTOSAI
Post by BATTOSAI »
check your oil pressure at the feed line of the turbo. If it´s too high you will blow the retainers on almost any turbo! Also check that your return line is above the oil level!
European Mx3 GsRT
Return to “Forced Induction”
