Will rims fit..
- userAttila19
Re: Will rims fit..
Thanx alot.. That's exactly what I was wondering about... That's a real help!
No time to slow down. 1995 MX-3 GS http://www.cardomain.com/memberpage/566272
Re: Will rims fit..
ok, then the wheels need to be:
100 x 4, 45mm offset (1.77in)
where 100 is the pitch circle diameter
4 is number of lug nuts ie holes on wheel to connect on car.
So the questionis this:
what is the range of offset that we can use?
45mm plus / minus what?
or does it have to be 45mm exactly?
i see wheels on ebay that are 100x4 but have offset of 40mm, 42mm, etc.
Re: Will rims fit..
The offset recommended by most wheel manufacturers for 17x7 is 38mm.
45mm is the offset for the standard rims, but they are a lot narrower.
I'm running 17x7 with 38mm offset, and it's just right.
Racing
\Ra"cing\, a. & n. from Race, v. t. & i.
The alchemy that turns base metals into heat, noise, power
and motion.
http://www.cardomain.com/id/storm99
and motion.
- jollyroger1965
7x17 4x100 et35
Just a simple question....will a 7X17 et35 be fine or will I have to use spacers or mod my suspension? I see from earlier posts that et38 is great but I have someone selling the above size to me real cheap and need to know if they will fit b4 I part with my £££'s
