Power Window Mechanism Swap
- 2fazed
Re: Power Window Mechanism Swap
Yeah, just the wiring harness from the hinge to everything inside of the door. That was the easiest way for me. Harness only costed $30, so it's not too expensive either. Kuruption has it right, I did what he did. I used my RS door panels and put tweeters in the existing window arm holes.
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
maldo
Mine is a '91 technically speaking, November to be exact. Guess I will have to do a second look as I must have mistaken the current wiring for the correct wiring. Oh well, shouldn't be too hard to find.
Here are the links to the auctions I won: Right side regulator
Left side regulator
Left side regulator
Chris Malden
MX-3 RSR
chris.malden@sasktel.net
chris.malden@sasktel.sk.ca
MX-3 RSR
marshmallow15
jeff i did the swap on my 92 rs. i dont have the wiring documented, but when you decide to wire everything together if you cant get a harness, let me know.
you can find the regulators all over ebay now for some pretty decent prices.. but im sure you can find some better prices at your local ecology or car-parts.com.
- team slideways
- team slideways
im lookin to do this swap too. im just trying to gather all the parts that i need right now. so far all i have is the driverside switch. i have a 92rs so i probably have to get the wiring harness huh?
92 RS: BPT, evo front mount, custom 2.5 in IC pipes, apex-i SAFC- II, GReddy type-RS BOV, rear disc swap, GTX front strutbar, oem GS lower rear tie bar, Topspeed1 axle back exhaust, 15" TSW wrapped in yokohamas, power window swap. NOT INSTALLED: GReddy turbo timer and CS downpipe.
maldo
For those who did the swap, how did you "glue" the window to the window regulators tray? That is my only concern with the swap, don't need a window falling out.
Chris Malden
MX-3 RSR
MX-3 RSR
u don't glue it theres 2 screwsOriginally posted by maldo:
1993 MX-3 GS V6 - Stock
2004 MazdaSpeed MX-5
2004 RX-8 - Project
2004 RX-8 - Project
marshmallow15
marlon's right. before you screw those two screws in, make sure you put the window in the tracks on the side (you'll have to put the window back in at an angle.) then once you do that, you'll have to lower the motor tray (either by switch or temp wiring to battery) so you can get access to screwing the window into the tray.Originally posted by maldo:
- team slideways
- team slideways
how do i check to make sure the window motor works without using the switches. i just swapped my driverside window stuff and the window wont move. it's either the switch or the motor cause i know the harness is good.
marshmallow15
hook the motor up to your switch using the harness (assuming you're hooking it up OE style with the proper harnesses) and then just retrofit a power source to the switch and test em that way. be careful if you switch the + and -, the window will work backwards, pushing up and the motor goes down and vice versa, but at least you'll know it works and you can just switch the switch wire signals.
- team slideways
- team slideways
I was doing this mod on my 93RS. I got the wiring harness taken from GS and it's OE one with original power switch. When I hooked up everything, the sliding seat belt turned on, so did the side mirror, but nothing happens to the power window regulator. I checked everything, and it seems everything's connected tight. I checked the white harness hidden in the black rubber at the door hinge and the harness on RS has less pins than the GS one. Does it matter or my regulator is broken? Please let me know. Thanks.
bungo
bungo
- 2fazed
No, shouldn't matter. Get a constant and ground from your battery and test your motor. You just switch the wires to make it go up or down. If they work, then test your switches. Might be your harness.
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
I'll check my regulator and switch, and then let you guys know if they're ok. Thanks.
bungo
bungo
I tested the window regulator and they seem to work fine. not sure about the power window switch since there's no way or other mx-3 to test it. I'd appreciate if you can tell me what more to test.
bungo
bungo
- 2fazed
Do you have a fuse in? Don't forget about that. Plug in the switch, get a test light. Push the buttons and see if it gets power. If your switches and motors are good. check the power wire on your harness at the door hinge. But I'm guessing it's the fuse.
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
I'm not really sure where's the fuse for the door (I assume it's under the steering wheel), but will check on that. About the light you mentioned, is it under the power window switch?
bungo
bungo
