Page 2 of 2
Re: Oh my, I just made a Cold Air Intake
Posted: October 11th, 2004, 6:47 am
by SIXPACK
hey guys..what should I do if my pipe only got one nipple. I need to connect the thin hose that go into the stock airbox.
Posted: October 11th, 2004, 8:17 am
by lakersfan1
I asked Ian about that and he said I could use a small breather filter to put over the end of the hose, so that's what I did. I believe he said it was just to recycle EGR gases for emissions.
Posted: October 11th, 2004, 9:24 am
by IanL
Yes, it 's just to pipe clean air into the EGR Vacuum Vent Solenoid Valve. If you don't bother with a breather, you could get the solenoid valve clogged up in time.
Posted: December 8th, 2004, 8:32 am
by Macen
I got my pipe from the US today. It was a 2.5" pipe. Will that have any affect? Is 3" better?
Got mine from an Integra 90-93.
EDIT: Correction: pipe was 2.75" outer diameter.
<small>[ December 10, 2004, 05:18 PM: Message edited by: Macen ]</small>
Posted: December 8th, 2004, 1:05 pm
by HKv6
Well, as I see it, the only thing is that you'll need different couplers.
Posted: December 8th, 2004, 4:06 pm
by babyblueMX3
you'll be ok with 2.5...the opening of the vaf is 2.5" anyways. it's the bottle neck of the whole system..what would be the purpose of going bigger
Posted: December 8th, 2004, 6:10 pm
by bmwm3guy
I'd hate to hit a puddle with that intake... Good luck :p Looking good though!
<small>[ December 08, 2004, 05:12 PM: Message edited by: bmwm3guy ]</small>
Posted: December 10th, 2004, 3:55 am
by catalyst
That front part of the intake has a clip for the hood support arm... I was going to take mine off too, but figured that I'd have to find some other way to keep the arm secured... I may remove the arm and put some type of gas struts on both sides to hold the hood up instead, but that'd take custom fabricated brackets, time, and ingenuity.
Posted: December 10th, 2004, 4:08 am
by bubbaflaat
My hood support just kinda chills on top of the fan shrowd... IDK it works and it has worked for over a year now...
Posted: December 10th, 2004, 4:12 am
by Macen
So does mine. No problem here.
EDIT: Does anyone know wher to find a 2.75 to 3.5" coupler or a 2.5 to 3.5" coupler?
<small>[ December 10, 2004, 05:20 PM: Message edited by: Macen ]</small>
Posted: December 10th, 2004, 6:12 pm
by hgallegos915
I have a dead nissan maxima because of a cai that i made with the pipe facing down
oh about the couplers... I payed like 3 dollars for mine on ebay..why are some people paying alot for them? all they are are just rubber or plastic o.0 On that second intake i see...how dod you fit the filter in the hole? did you have to do any cutting? how is the throttle response? I have a short intake and it ounds nice but well..it is getting hot air :p also about the hood support..yeah mine chills on top of the fan support also.
Posted: December 11th, 2004, 7:01 am
by Calkidd
When I took off my stock air intake I drilled out the rivets where the hood rod support was attached to the air intake.
Here is a picture of what I did when I reinstalled back on the car.
Hood Rod support
It really works well.
Bryan
