KLZE opinion
- babyblueMX3
Re: KLZE opinion
big difference...and 2 second less on the quarter mile too
..you'll love it trust me
RIP 400whp ZE-T MX-3
Re: KLZE opinion
I'd rather have that new KLDE crate engine. Think about it. What would it cost for new Throttle Position Sensor($160), Idle Air Control Sensor (I've heard $600 for that one alone), new timing pulleys ($150), new hydraulic timing tensioner arm ($150), all new seals and gaskets (worth over $250), new water pump ($60), new spark plug wires ($80), NEW distributor ($300), new crank pulley ($200). I'm at $2000 already in the stuff that might need replacing on any second hand motor, and I' haven't even included the block itself, the new intake manifold, and the new throttle body. And the KLDE is set up for passing emmisions.Originally posted by Ayaz:
What would be better. Getting a brand new crate (brand new) KLDE for $2000US or a used KLZE?
It has about the same torque as the KLZE, and the computer for the KLDE can be had for $100 easy whereas a KLZE computer usually runs $250. If you really wanted the extra horsepower, you could always stick a set of performance cams on and call it a day. There are people on ProbeTalk that dyno just as high, if not higher than KLZE's with thier KLDE setups.
Just something about new I can't say no to.
Re: KLZE opinion
I love my ze compared to the k8!
As for the 2000 dollars mentioned for repairs. If you inspect the engine before/as you install it, chances are hardly any of those items mentioned will need to be replaced. In my case all of those items where in perfect shape.
Have a compression test done by the engine supplier.
Just get your flywheel machined and put in a new clutch, tune it and your good to go.
I have noticed very few people on mx6.com that have the kl03 output the same as a ze, without a lot of work done.
But new is nice also. Either way you will like your mx3 much more.
92 MX-3 GS 2.5 KLZE
14.385 @ 98.21
14.385 @ 98.21
Re: KLZE opinion
No one on probetalk or mx6.com dyno's the same as a klze without using one or more of the KLZE parts including the IM, cams or heads. Unless they are turbo'ing or using NOS.
The KLZE is an OK motor. The short as hell gearing on the MX3 isn't suited well for this engine. If I had to do it again, I'd much rather go with a turbo 4-cylinder than a KLZE, they simply make more power.
DONATE TO MX-3.COM
DONATE TO MX-3.COM
Re: KLZE opinion
I also want to do the ZE swap, but I do not have the tools or space to do this. Is there any where I can get the complete swap done, eng/curved neck, etc. that is close to Ottawa? I know of Aspec, but a little far. (lazy :p ) Anyone know of shops near here that do this? Does Osaka do this?
thx.
thx.
Re: KLZE opinion
Does anyone know how far Noyan USA is from Toronto ontario?
- 93-Spec-Edn
Re: KLZE opinion
Has anyone from western canad abought from noyan? Did u get charged taxes etc?
92 mx-3 RS RIP | 95 mx-3 GS sold | 93 mx-3 GS SE sold | 95 mx-3 GS present
Re: KLZE opinion
That estimate was assuming only one mod - Interprep cams. According to Interprep's site, a KLDE with KLDE intake and Interprep 280 cams do 190 HP and 174 lb/ torque. What're the factory specs on a curved neck KLZE anyways?Originally posted by Gro Harlem:
Re: KLZE opinion
200PS = 197 hpOriginally posted by lakersfan1:
223Nm = 164.5 ft-lb torque
Re: KLZE opinion
Show me a dyno sheet from someone independent of their site, otherwise that information is totally false.Originally posted by lakersfan1:
You are trusting what a commercial website says as fact??
Even guys on PT with mikeseli's reground camshafts (and he has numerous different "specs" to choose from) never hit 170whp without upgrading the head w/KL131 ones and installing KLZE im's.
DONATE TO MX-3.COM
DONATE TO MX-3.COM
Re: KLZE opinion
I'm a sheep. What can I say?Originally posted by Gro Harlem:
You are trusting what a commercial website says as fact??![]()
Re: KLZE opinion
That's from the curved neck one with the KL01 heads?Originally posted by IanL:
Re: KLZE opinion
Its a JDM Eunos 800 (Millenia) so its the curved neck - I don't know about heads, cams; I believe its the factory spec, but I had to use Babelfish.
Re: KLZE opinion
As far as I am concerned, all motor the ZE outperforms the DE hands down. I was getting beat all the time by my friends in their civics and integras and preludes. Mind you that ws wiht the 08. I dropped in the ZE(without the MS8 mani or TB) and none of them can keep up with me anymore. One of them sold their prelude and bought a turbo eclpise just so he could still be the fastest of all of us. I say you shoud go for it. Even though you have more tuning options for the DE form places like CZT I am hearing a lot of bad things about them.
