Page 2 of 2
Re: kf-ze??? What is this from??
Posted: December 9th, 2002, 8:25 pm
by Aston Wards
The intake manifold on the KF is VERY similar to a K8, slight difference in the curve, with a bit of swearing everything hooks up fine, however, hooking the rest of the engine up requires quite a bit more foul language, don't bother, more hassle than it's worth, TRUST ME!
Posted: December 9th, 2002, 11:38 pm
by David Coleman
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Vicious:<BR><STRONG>The intake manifold on the KF is VERY similar to a K8, slight difference in the curve, with a bit of swearing everything hooks up fine, however, hooking the rest of the engine up requires quite a bit more foul language, don't bother, more hassle than it's worth, TRUST ME!</STRONG><HR></BLOCKQUOTE><P>I'm sure it doesn't seem like it's worth it, especially considering you only gained ~15ft/lbs of torque at best. Now with a KLZE swap, you gain 70bhp and 60ft/lbs of torque also. Definitely worth it, IMO. ;)
Posted: December 10th, 2002, 7:35 am
by jeroentje_nl
I have a 323F / Lantis has a KFZE. 2.0L<P>It has 145 Hp<P> Image
Posted: December 10th, 2002, 2:38 pm
by David Coleman
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by jeroentje_nl:<BR><STRONG>I have a 323F / Lantis has a KFZE. 2.0L<P>It has 145 Hp<P> Image </STRONG><HR></BLOCKQUOTE><P>What is the compression ratio? I suspect you have a KFDE, not the KFZE, especially since you site you have 145bhp instead of 170 like the KFZE has.
Posted: December 10th, 2002, 5:15 pm
by IanL
I think its not so easy, getting KLZEs on this side of the Atlantic, there doesn't seem to be the thriving market for them you have in N America.<P>Might have to settle for a KLD out of a Xedos 8. Not sure about the manifold shape, but I think it curves forward?
Posted: December 10th, 2002, 5:44 pm
by Steeb
i wonder if the kf-ze was a frankenstein motor like ls/vtec or something just not so ls and so vtec since mazda did use those vtec. i mean more something like 1.8 motor with ze cams and id think a new crankshaft since the bore on the kfze is uped to 78 from 75 in the 1.8 throw in .8 higher compression pistons and i believe that is probably what bumps the 1.8 to a 2.0 and the 130hp to 170 hp of course with some mazda tuning of course. i would think the 145 hp is just a different variation of the 170hp kfze. kinda like how we have the 164hp kl's and aus, jap, etc get the 190+hp versions. but then again this is just seems logical to me after you look at everything at once. who knows i could be totally wrong.<BR>kf-ze page <A HREF="http://members.rogers.com/sofronov/Cars ... antis.html" TARGET=_blank>http://members.rogers.com/sofronov/Cars ... is.html</A> <BR>1.8 mx3.com page <A HREF="http://www.mx-3.com/brochure/specifications.cfm" TARGET=_blank>http://www.mx-3.com/brochure/specifications.cfm</A> <BR>small info on increasing displacement-stroker kits =] <A HREF="http://www.todaracing.com/products/hond ... r_kit.html" TARGET=_blank>http://www.todaracing.com/products/hond ... it.html</A>
Posted: December 10th, 2002, 6:00 pm
by IanL
KF data on <A HREF="http://digilander.libero.it/mazdaxedos/ ... chdata.htm" TARGET=_blank>http://digilander.libero.it/mazdaxedos/ ... ta.htm.</A> Same stroke as K8, bit bigger bore, usual variation in CR between Japan and Europe.<p>[ December 10, 2002: Message edited by: IanL ]
