Page 10 of 17
Re: Sleeper6's Gold 92GS Rebuild opinions wanted!
Posted: March 11th, 2012, 10:44 pm
by Sleeper6
Oil Pump is officially off the car, taking it to work to remove the inspection plate and check out the gears tomorrow, here hoping for carnage on the inside.
Pics to follow
Re: Sleeper6's Gold 92GS ..confused...
Posted: March 13th, 2012, 1:09 pm
by Sleeper6
So pulled the oil pump and the inspection plate. Confusing part, its perfect from what we can see. Ordered a new pump just in case and plan on running a wire along the feed to the oil pressure sender to make sure theres no blockage.
I am really confused at this point, 0 Psi and there is nothing inside that indicates catastraphic failure... And Im positive on the oil pressure with a mechanical gauge new sender and audible engine noise after starting it now for the 6th time since the light came on.
Posted: March 13th, 2012, 1:28 pm
by Josh
In that case, I would pull down the bottom of the rod caps and inspect each one, same with the mains. If you have bearing failure you will loose all oil pressure even though the pump is working.
If they are fine you can torque them back into place with no issues just don't pull the bearing out of the caps if you don't have to.
Posted: March 14th, 2012, 9:26 pm
by Sleeper6
Josh wrote:In that case, I would pull down the bottom of the rod caps and inspect each one, same with the mains. If you have bearing failure you will loose all oil pressure even though the pump is working.
Pretty sure your right, now with everything off and put back together I have side to side movement on my connecting rods. Thinking thats the problem so going to set time to pull the bottom end apart.
Re: Sleeper6's Gold 92GS bad bearings
Posted: March 17th, 2012, 5:43 pm
by Sleeper6
I <3 PT.
After some long talks and pms back and forth with some PT members about kl internals I was convinced to put oil in and fire her up, glad I did! 62psi at first start and she runs at about 30psi idling at 800-1200 and up to 50 psi cruising. Needless to say shes back together, Oil pressure guage is now mounted in cabin and I have a few more KL points then I did to start with! :lol:
^What a KL looks like sans oil pump and pan
^just an awesome pic to me
^Guessing this motor hasnt had an easy life from the looks of the internals...
VIDEO LINK BELOW
Small video of what scared the bijesus out of me when I was about to put the oil pump in for anyone wanting a refrence
^Alien landing site. heh no just all the bits that came off in process, strainer had no bits inside thankfully so all is good for now.
So in other news headed to a jy tomorrow to hopefully score a G4 intake and VCs!
Re: Sleeper6's Gold 92GS Its alive! again!
Posted: March 17th, 2012, 8:46 pm
by AaronTietje
Wow great job and good call on doing the oil pump. I hope it runs strong for you now.
Posted: March 17th, 2012, 11:54 pm
by Will Thomas
Saweet! We might get our cruise on sooner than we thought. :D
Posted: March 18th, 2012, 12:25 am
by Sleeper6
Will Thomas wrote:Saweet! We might get our cruise on sooner than we thought. :D
Ya now if aaron would just get his going already... Lol
Posted: March 18th, 2012, 5:15 pm
by AaronTietje
Hey, I go out in the garage and look at it every now and then. 8)
Posted: March 27th, 2012, 9:46 pm
by Sleeper6
So after messing around a bit I have my Gauges set up how I like, although soon as the budget picks up Ild like to swap out the sunpro for an autometer unit.
Also did some basic maint. to the car as well, feeling like it was running a bit rich so I swapped out my 200k mile O2 sensors for some new ones. Looks like the back bank was running a tad rich lol.
And I sorted out a small vac leak from my canister to the 1st VRIS solenoid connection that had come loose. Hopefully Ill have a G4 intake/VC combo soon so I can redo them permanently in some proper quality hose.
Re: Sleeper6's Gold 92GS interior gauge/sensors
Posted: March 29th, 2012, 12:21 pm
by Will Thomas
Glad to hear all is well. I am going on vacation next week and will be back April 16. We will have to get together for a cruise when I get back.
@Aaron-Will you be ready by then?
Posted: March 31st, 2012, 6:09 am
by youdirtyfox
Gauges look smart, do love the green :D
Posted: April 7th, 2012, 11:04 pm
by Sleeper6
youdirtyfox wrote:Gauges look smart, do love the green :D
THanks!
Anyhow swapped my winter tires over today back to my summer treads. I feel bad for having a tech inspect my car the other week as I found my rh ball joint is about to fall out when I did the swap over :oops: So I have a new one picked up ready to go in after easter and a nice beautiful block off plate from king6 w.decals that I need to rock. (sick piece btw the logo is actually engraved!) Although now I have to debate to try and put it on now or wait until I find a G4 intake and do it then as it would be 100x easier without the intake on.
Posted: April 8th, 2012, 7:41 pm
by Sleeper6
Tried to do some regular maint. after getting home from easter dinner. I sat out in the rain to get it all apart as my rh ball joint had about 1/4" of play and I didnt feel comfortable taking her to work that way, so I had picked up a new one from autozone sat. Well after dropping it out in 2 pieces (it shattered in my hands at the socket) the replacement was the 93+ fat design :evil:
I hate lazy counter guys, now I have to drive the honda :oops:
Posted: April 18th, 2012, 8:47 pm
by Sleeper6
Ball joint fixed, now awaiting my package and getting some roloc discs for my next project :twisted:
