weede`s KL-ZE Supercharger - Megasquirt
- AaronTietje
Re: weede`s JDM MX-3 KL-ZE Supercharger
Congrats on the 1st. Love the pics, I'm a big fan of your car.
you only have a straight cut 3rd gear?
- Dali
I would be up for a in and outlet flange. Thats pretty much all I need to put mine in, no time or equipment to make my own right now. How much?
1993 White gs klze.
i'd be interested in a mounting kit and inlet and outlets too.
- kulluminati777
wow the new pics are hawt!
weede_klze
Yes, only 3rd. This is the weakness part of gearbox.mx3matt wrote:you only have a straight cut 3rd gear?
in and outlet flange with gaskets will be 50euro + shipping
mounting kit will be 100euro + shipping.
kyser182
simply.. wow
ready every post of every page.. im new to this fourm.. i wish i had the time and money because your care is amazing!
1993 MX-3 GS
weede_klze
Final project:
Cutted and fitted
AEROQUIP:
Oil filter adapter:
And now i`m preparing place for gauges
Cutted and fitted
AEROQUIP:
Oil filter adapter:
- Josh
Nice, I cannot wait to see this put together.
Are you planning on eliminating the clutch and going for a smaller pulley?
weede_klze
Of course, standard pulley will rotate about 8,5k rpm (aprox. preassure 0.3bar) . I`ll use a 58mm pulley which gives 14-14,5k rpm which is nominal speed of Eaton M62 (aprox. pressure 0,7-0,75bar).Josh wrote:Nice, I cannot wait to see this put together.
- Josh
Nice, are you going to be running some kind of waist gate as to not run full time boost? I have been researching the 62 and the 90 and seems the 62 with the smaller standard size pulley is the best option. But I want to save a little fuel economy while driving so I have been looking into incorporating a waist gate to help releave some of the boost under normal driving.weede_klze wrote:Of course, standard pulley will rotate about 8,5k rpm (aprox. preassure 0.3bar) . I`ll use a 58mm pulley which gives 14-14,5k rpm which is nominal speed of Eaton M62 (aprox. pressure 0,7-0,75bar).Josh wrote:Nice, I cannot wait to see this put together.
IMACHU2
You never mentioned your 1/4 mile time at the meet???
Dominic Toretto's whip is a MaZda and his cell phone number starts in "(323)"
My work log http://mx-3.com/phpBB3/viewtopic.php?f=46&t=72471
weede_klze
14,9 but my engine doesn`t generate full power, only 180 hpIMACHU2 wrote:You never mentioned your 1/4 mile time at the meet???
Waste gate is used with turbo systems, not supercharger - I will have full linear boost from low rpm. I`ll use bov to open intake when throttle is close. Thats itJosh wrote:Nice, are you going to be running some kind of waist gate as to not run full time boost?
In your case the best solution is clutched SC - normal, economy drive you simply dont use it. But you must have MAP sensor in intake manifold to control the pressure with mapped ECU.
- Josh
hmm, that was my first initial thought, but then I started looking at like the 62 out of the Cobalt and a couple of others, and they have a regulator valve to keep boost levels low during normal driving. a similar valve would be like a waist gate, and you could plumb it in a such a way to do the same thing or act in the same way. I know there is not much room to mount a colbalt M62 int he AC location so I was just looking into other options for like benefits.weede_klze wrote:Waste gate is used with turbo systems, not supercharger - I will have full linear boost from low rpm. I`ll use bov to open intake when throttle is close. Thats itJosh wrote:Nice, are you going to be running some kind of waist gate as to not run full time boost?![]()
Nice work on your project though, I look forward to seeing it completed.
weede_klze
Last stage of preparation
Oil filter relocation adapter
adn fitted:
Set for additional pulley for supercharger belt
...and fitted
Adapter for fuel rail which is necessary to install Turbosmart fuel regulator
And washed car preparing for engine rebuild
Next stage is remove engine from car and full rebuild on millenia s rods and of course supercharger (still not clutched for time when engine is run in)
adn fitted:
...and fitted
