The "Quick Question" Thread
RobMinhas
Re: The "Quick Question" Thread
Post by RobMinhas »
Ryan wrote:There's an actuator in the passenger door, and a sensor on the driver's side lock. It just relays the information, and the passenger side copies exactly what the drivers side does. It doesn't sense position, it senses change in position, so if you locked it with your new FOB while the passenger door was open, and then someone closes the passenger door, you'd have to hit unlock, then lock again to get it to lock the passenger.
So essentially, if I install an actuator in the drivers side, so long as both doors are shut, I'll be able to lock and unlock them both?
Thanks for the info on the locks, I always thought they were just magical haha
EDIT: And one more thing, I could go down to my wrecker and take an actuator from a MX3 passenger side door then, right? :D
Ryan
Post by Ryan »
Uh no, not really. The wireless kit you buy will probably have two actuators anyway.... and you need to module that receives the wireless signal. Also, you'd need a mirror'd unit to fit in the driver's door, the passenger one won't fit.
wagZE
Post by wagZE »
Yes when adding keyless entry in these vehicles you need only one actuator; on the driver door. Same as mx-6's 240sx's list goes on. wire up 2 relays for addiding aftermarket actuators from your alarm. Check out the12volt.com for the info you will need (vehicle wiring for what wires to tap in your car) & relay wiring for how to go about adding keyless entry. GL
1 mx6 88 LX auto 2.2l 4cyl
2 mx3 93 gsze bought w/ mods
4 mx3 GS SOLD-
2 pgt primered 5 spd KL SOLD
RobMinhas
Post by RobMinhas »
Anyone know if 94-98 Mazda Protege Struts fill fit on an mx3? The ones in question are here: http://calgary.kijiji.ca/c-cars-vehicle ... Z323982821
The price seems decent so I'm considering upgrading my struts after getting a hold of some springs.
Ryan
Post by Ryan »
struts yes, strut tops, looks like a no. To know for sure get the model numbers off of him and check it on KYB's site.
Best to get something with a damping rate designed for your application though... then again you'd probably never notice.
RobMinhas
Post by RobMinhas »
Ryan wrote:struts yes, strut tops, looks like a no. To know for sure get the model numbers off of him and check it on KYB's site.
Hmm, I would prefer a coil over set that's designed specifically for my car so I think I'll wait till I can find a good price on a set.
RobMinhas
Post by RobMinhas »
Also do you guys know if a boss kit without the black "shroud" around it will still work fine? Just curious as Shayne gave me his old one and it's missing the shroud, my plan was to find a shroud from a different boss kit at a junkyard or something but if that ends up being fruitless I'm wondering if I'm still good to use it.
Evo_Spec
Post by Evo_Spec »
RobMinhas wrote:Also do you guys know if a boss kit without the black "shroud" around it will still work fine? Just curious as Shayne gave me his old one and it's missing the shroud, my plan was to find a shroud from a different boss kit at a junkyard or something but if that ends up being fruitless I'm wondering if I'm still good to use it.
yes it will.
all it is, is to look pretty, other than that it's really nothing. You could make something with PVC piping or something along that line
this is kind of how it looked when i bought it, the piece would just slide up and down to adjust
maybe that gives you some kind of idea how it should be
RobMinhas
Post by RobMinhas »
yes it will.
Gotcha.
I'd like to make it look a little nicer if I could, so I'm gonna try to get one. Either way it should work out good thanks to you man.
And I looked into installing that intake you hooked me up with, I got a bolt to stuff the extra hole so I'm set there. Had some difficulty finding couplers to fit, although I only checked Rona because that was the only place I could stop at ahaha. I'm gonna check out some auto specific stores for the couplers, got any recommendations? I'm also hitting up pick n pull and another wrecker on 52nd, you needing anything from there while i'm down there?
Evo_Spec
Post by Evo_Spec »
RobMinhas wrote:And I looked into installing that intake you hooked me up with, I got a bolt to stuff the extra hole so I'm set there. Had some difficulty finding couplers to fit, although I only checked Rona because that was the only place I could stop at ahaha. I'm gonna check out some auto specific stores for the couplers, got any recommendations? I'm also hitting up pick n pull and another wrecker on 52nd, you needing anything from there while i'm down there?
mopac has a good selection of couplers, lil pricey but they're good vibrant couplers.
and i can't really think of any parts i want at pnp prices XD
RobMinhas
Post by RobMinhas »
Not even a black hood? :D
Evo_Spec
Post by Evo_Spec »
RobMinhas wrote:Not even a black hood? :D
lol if you wanna fit it in your MX then sure =D
RobMinhas
Post by RobMinhas »
If it's there, and you want it, I'll bring it home, that's a guarantee haha
RobMinhas
Post by RobMinhas »
Can anyone help me find a link to change an alternator belt? I've never changed one before and I'm gonna try mine tomorrow.
Evo_Spec
Post by Evo_Spec »
RobMinhas wrote:Can anyone help me find a link to change an alternator belt? I've never changed one before and I'm gonna try mine tomorrow.
just come over, i'll help you
