Want to improve performance
I'm looking for any way I can make performance improvements on my MX-3. If you have done any and know of ways that I can, please let me know. I don't know much about cars but I got an excellent mechanic that does.
Re: Want to improve performance
Cheaper options:<BR>PRM Jetstream cold air intake, feed it fresh air.<BR>8.5mm Magnacore spark wires.<BR>Buru Silverstone Sparkplugs.<BR>Change muffler from single to double out. Standard GS muffler will fit perfectly.<P>more expensive options:<BR>catback exhaust system or full free flow exhaust system which includes header, highflow cat and catback system.<BR>1.6 B6T swap or 1.8 BPTurbo swap.<P>other stuff:<BR>front and rear strut bars.<BR>15",16" or 17" rims with wider width.<BR>etc.<P>Other peeps may be able to add more
ProtegeSTS
performance as in what? engine, suspension, braking??<P>Simple stuff would be to add a 2.0" cat-back exhaust, PRM intake, eibach springs and tokicos, a rear sway bar, and better brake pads.
-93 MR2
#129 E-stock
#129 E-stock
osargeant
I would also add the Unorthodox Racing lightened pulley to the list of performance mods for a MX-3. <P>It really improves the low end and proves a hp/torque gain throughout the entire rpm power band.
JSpec Turbo MX3 (1.6 DOHC)
http://www.cardomain.com/memberpage/310985
Port and Polished Head, Ported Intake Manifold, Valve Job, GTX Manifold, Hybrid Turbo, Cone Filter, 2.5" Exhaust, 2.5" Downpipe, ACT Street Clutch, Lightened Flywheel, MSD 6A Ignition, Boost Retard and SS Coil, Magnecor Plug Wires, Denso Iridium Plugs, UR Lightened Pulley, Spearco FMIC, Turbo XS BOV & MBC, BEGI RRFPR, Supra Injectors, Walbro 255 Fuel Pump, Autometer Gauges, Pivot Shift Light
- Wildman640
Where is a good place to buy the pulley from?
Pope52
<A HREF="http://www.nopionline.com" TARGET=_blank>http://www.nopionline.com</A> they have everything you need for a V6 engine but also some 4-cyl stuff.
BlueprintMX3
Start off with a nice air intake.. Match it with some hurricane headers, and that should boost ya some. if you want more.. get the swap or turbo that bad boy. Ace what side of El Paso you From?? im from EP too! Hit me up maybe we can get together..
