it runs bad when there is any change in throttle imput.. (bogs and sometimes pops)
no clue why this is happening but i thought it was engine timing (belt) so i re did it and it was and is correct.. so i dont know right now..
it is driveable but it stalls out sometimes when i come to a stop.. the idle is very inconsistant! i have my tps set to 0.650
throttle screw is open a few turns and my throttle plate is at zero % .. it should run mint??
anyways any change in throttle it bogs ... but then a couple seconds later it will run normally if i continue to hold that throttle position, it seems like its missfiring.. no matter where on the throttle if i hold it in one position its all good, but when i change positions (while driving standard is obviously alot) for a few seconds after the position is changed it bogs and is not very happy. but then is happy? weird.. any ideas guys>?
