The new acquisition is rusty...which is very unusual here. These K8 powered cars usually reach end of useful economic life, because of a small list of the usual mechanical failures, that no one can be bothered fixing /can afford to fix...water pump, distributor, auto trans etc.....but never rust.
This one is not the top of the range, high spec HI-FiX model, no ABS, but has Sunroof, and some accessories fitted. One of those is the rear hatch mounted EUNOS badge light. These things have to be disabled here when the imports are go through a mandatory "road worthiness" process when first registered for road use in this country. That is usual done by disconnecting the wiring to disable the power supply.
I removed it out of curiosity .....this accessory stuff is not really my thing. I will bench test it to see if it works Ok and then might sell it. Its a simple wiring setup..into the tail light unit,
Some pictures of it in place and being removed and its connection to the tail light ...
 missed!
 missed!
