i have one thing left to buy before i have a complete turbo kit and that is my manifold i have a stock 4g63 t25/t28 turbo from my friends eclipse will this manifold bolt on to the bp block i know its for a miata but isnt it the same block just
sideways any help will be appreciated
http://www.ebay.com/itm/220679622095?ss ... 3926wt_911
turbo manifold question
Re: turbo manifold question
Yes it should. But because of the orientation of the Miata engine it's made to fit on the side, not the front so it may interfere with your rad etc. Make sure they have a good return policy or be ready to do some modifications if necessary.
The flange will fit though.
- RS_OBD'oh_2
just get the right mani with the right bolt pattern for your t25.
I have a couple good links you may want to check out on my log:
http://www.mx-3.com/phpBB3/viewtopic.php?f=46&t=69074
Here is the site for the turbo mani.
http://jgsturbo.com/index2.html
Edgar7654
well i just finish ordering my manifold hope i get it soon and got oil lines today anyone know how much psi the bp engine can hold reliably mine has about 150 seller said 93k but idk it had too much sludge for 93k plus the fact that it came from a 91 protege lx
- RS_OBD'oh_2
it's about tuning and CFM, not really PSI.
if it makes you feel better, I'd say keep it under a bar. And make sure someone who knows what they are doing tune it.
