When I first got the car before the rebuild, I was getting 32 mpg. I have a 94 1.6 dohc with 50,000 mi on the rebuild. I get a constant 23 mpg whether I drive conservative or aggressive. With AC, or without AC. I have smoke out the tail pipe at start-up and occasionally upon acceleration. The plugs are clean. I go through about a quart of oil every 400-500 mi. It runs pretty well otherwise.
Any ideas???
Air / fuel mixture off maybe???
timing belt off by a tooth???
gas mileage horrible and major oil consumption
pauleatstoomuch
'94 Mx-3 RS - All Black - Fully Rebuilt B6 DOHC .020 over, CAI, 2 1/4" exhaust, SE Leather Seats, Pioneer DEH-P4000UB, JVC 6.5" in the doors, Rockford Fosgate 400W, 2 12" Dual Subs in Bandpass Box
- Ryan
Re: gas mileage horrible and major oil consumption
A bad rebuild....
Valve seals leaking hence smoke on start up. Add a quart of Rislone on your next oil change it may help reseat your rings.
Dark_Rider2k3
I think you have 2 problems, both of which are due to the rebuild. The valve seals being the first. Do you by chance have a fuel leak? Check the injectors for leaks.
