Something draining battery :S
Mariob316
Post by Mariob316 »
Ok, so someone hit my car this weekend, nothing major just really scratched and broke driver side front marker plastic.
Anyways, since then my car battery dies overnight and the left blinker (the one that broke) blinks fast (the bulb is still good)
But when i put my flasher left it doesnt flash, the back one does tho (really fast). Also when i put my right flasher on, the left one stays on :S
And one more thing, the side marker (beside the wheel) doesnt go on but when i lock my doors, all the lights go on including the side marker.
john1983
Re: Something draining battery :S
Post by john1983 »
that sounds like you have a burnt filiment
92 MX-3 6cyl dohc 24 valve K8 cold air filter custom exhaust drift body kit carbon fiber hood 17" focal rims Kenwood KDC-MP635 headunit Pioneer 6.5" componet door speakers and 4" rear speakers 500 watt boss amp powering 12" sony explod
My Work Logviewtopic.php?f=46&t=76603
Mariob316
Post by Mariob316 »
Do you think it has anything to do with my car battery dieing? Tomorrow im going to do a light test by removing each fuse.
Ryan
Post by Ryan »
It sounds like two wires/contacts were pushed together during the accident. The fast blink is caused by incorrect resistance in the circuit, but usually by too-high resistance, not a short. So perhaps not.
Take out the electrical components in the region and inspect them for damage. The signal assembly has a double filament bulb in it, one for the running lights, and then the other one flashes. If those contacts got crossed at all, it will wreak all sorts of havoc.
Mariob316
Post by Mariob316 »
Alright thanks guys!!! I shall check it out
