No cam sensor input on MS2
- mx3worthy4link
so i got a crankshaft signal to MS, but I cannot get a camshaft signal in the composite datalog. I tested the voltage at the #3 pin of the DB37 connector and its seeing 0-5 volts on cranking but I still have no signal, anyone have any ideas?
92 MX-3 GS KL-DE, 15.8ET with a bad 3rd gear
03 Worthy 4-link dragster, 555c.i BBC, 7.62ET
Re: No cam sensor input on MS2
What's the part number on your disty? Is it TOT57071 or TOT57072.
- mx3worthy4link
TOT57072
I was just checking in case you had a newer disty with no cam sensor.
- mx3worthy4link
yeah like I said megasquirts seeing 0-5v going into the board so its working but the unit isnt picking it up :/ i cant figure out why
