Tried to bleed the clutch now I have no pressure please help
I followed the online manual on bleeding the clutch and the pedal went stright to the floor now i have no clutch. How would i go about fixing this?
1993 Mazda MX-3 GS KLZE
- Ryan
Re: Tried to bleed the clutch now I have no pressure please
you must have let air into the system.
Bleed it more. You can also just leave it open and let it gravity bleed for awhile. Make sure your reservoir is full at all times.
Either that, or your slave fell off of the clutch fork or something else, but its not likely.
everything is connected and ive been bleeding for what seems like ever. I even went out and bought a mini Vac hand bleeder and still no luck. Is there a trick or something im missing?
- Ryan
IDK man, unless you did something wrong. It took me a few days worth of patience to bleed mine.
Two people to bleed right, one operating the pedal and the other opening and closing the bleeder screw. Gravity bleeding may work IAW Ryan.
New Master and a new slave cylinder and now she's drivable. Guess its a good thing I decided to bleed the breaks cause the old slave cylinder was almost completely hollow.
NIce to hear you fixed it.
